B7800 stalled, can't start it (safety interlock ?)
   / B7800 stalled, can't start it (safety interlock ?) #1
TJIC
NH
Kubota B7800
posted this here but maybe this is a better location.
I stalled my Kubota B7800 this morning and the normal restart procedure isn't working. I imagine I tripped some safety interlock but I can't figure it out.
I had my tractor idling, neither PTO engaged, in low gear. I was on the ground next to it and wanted to back it up 12", so I reached over with one hand and depressed the "rear" speed control foot pedal.
The tractor moved backwards 1", then - because the engine RPMs were low, and the front wheels were in a rut, it stalled out.
OK, no big deal, it happens.
Hop on tractor.
* Turn key to off
* verify both PTOs are off
* gear selector to neutral
* 3PH lift/lower selector to neutral
* RPMs to middle
* butt in seat, so weight switch is engaged
* clutch fully depressed
* turn key to preheat, hold, then to start
nothing.
All the proper lights are on, but the starter doesn't crank at all. (which is why I think it's a safety feature).
I pulled out the manual and walked through the proper starting procedure, step by step, and I sure think I'm doing everything correctly.
My only hunch is that by stalling it out in a rut, I've maybe done something different than my usual dumb stuff.
Any insights or help? I'd love to unblock my driveway!
Thanks,
TJIC
   / B7800 stalled, can't start it (safety interlock ?) #2
Duplicate post in owning operating?
Check the directional pedal to be sure it is centered. Might have stayed off center since you were pushing it gently with your hand...
   / B7800 stalled, can't start it (safety interlock ?) #4
Gotta love those easy fixes. :thumbsup:
UNUSED 2025 INDUSTRIAS AMERICA 227T HYD TILT TRL (A50459)
UNUSED 2025...
2019 CATERPILLAR 279D SKID STEER (A50458)
2019 CATERPILLAR...
Warren Spreader Bed Insert (A48837)
Warren Spreader...
2017 Kenworth K370 New Way 16RLCN 16Yd Rear Loader Garbage Truck (A48081)
2017 Kenworth K370...
1998 Ford F800 10 Yd. Dump Truck (A48081)
1998 Ford F800 10...
UNUSED KJ CHICKEN COOP (A50460)
UNUSED KJ CHICKEN...
