B7800 Oil Leaking At Front Axle Bracket
   / B7800 Oil Leaking At Front Axle Bracket #1
rural2
Bronze Member
South Coast Oregon
2004 B7800HSD
I have a pretty good gear oil drip coming from behind the front axle pivot bracket where the front of the axle attaches to the frame. I seem to recall reading on here that there is an o-ring or seal or something back in there and it was a fairly easy fix? I am having no success with a site search, can someone help me out with advise, a link or part number please?
   / B7800 Oil Leaking At Front Axle Bracket #2
Kubota has online parts books you can look at. That will give you part # and good idea how it all comes apart.
Thank you for the Kubota link! Looks like an o-ring (part #04811-50550) and a pretty simple fix.
WHITE CI-7 DRAW WORKS POWERED BY TWIN DETROIT 12.7S (A50854)
WHITE CI-7 DRAW...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A48081)
2015 Ford F-550...
2013 ACURA ILX (A50324)
2013 ACURA ILX...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A51039)
2018 John Deere...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2014 AMERITRAIL, INC. TUGGER TRAILER (A50854)
2014 AMERITRAIL...
