B7800 float question
   / B7800 float question #1
72chevy4x4
Bronze Member
John Deere 3038e
I just bought this little tractor-don't 'think' it has a float, but sure would be handy with the snowplow I've installed on the front (my fabrication-not the factory unit). I've never used the kubota w/ a float-if I had it would it powered partially in the down position, but when pushing the joystick fully down it is in float position? Does the float position have a detent?
I'm probably at 4 hours on the clock-has anyone had luck w/ a dealer charging the difference and swapping on a new float valve in place of the stock unit? Does anyone know an approximate cost?
   / B7800 float question #2
You should be able to float the loader. Push your joystick forward, and when it feels like it is all the way, push a little more to get past the detent, then you will be in float.
   / B7800 float question #3
All Kubota loader valves have float. Yours does too. Sometimes at first you really have to push to get to the float detent. When the lever stops just push a little harder and it will pop into float.
thank you-you are correct. I looked through the manual for the loader and there it was! Just got done using my old Ford 1510 and realized it has a float position-I've used this thing for 5 years w/o realizing this. Only thing is one must really jam the joystick up to lock it into float-nice to have this feature-would have come in handy when I was doing grading years back :)
   / B7800 float question #5
Think that my float position still allows for down pressure on the snowplow because it scrapes pretty hard. Assume that there is an adjustment that will allow it to float? Anyone with experience in how to adjust it?
   / B7800 float question #6
I would imagine that is because that loader on that M series weighs a lot. Even in float, the weight of the bucket and loader arms would be pushinf on the ground.
   / B7800 float question #7
Yes the plow and loader arms are pretty heavy and it comes down on the road with more weight than a plow on a truck hinged at attachment points. Just wondering if it really is floating completely or some hydraulic pressure still is there to push it further. When using the nonfloat position I can lift the front end easily and when I push all the way forward to the detent float position it releases. What other checks can be made? May be a gauge on the line to the FEL cylinder to look for pressure would be a way to know for sure.
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
2015 Z Master Professional 5000 Series Model 74942 60in Zero Turn Mower (A50322)
2015 Z Master...
Unused Delta Crash...
2018 CATERPILLAR 289D SKID STEER (A51242)
2018 CATERPILLAR...
2024 AGT KFE-20 2,000lb Electric Forklift (A50322)
2024 AGT KFE-20...
2019 BOBCAT T770 SKID STEER (A51242)
2019 BOBCAT T770...
