B7800 backhoe
   / B7800 backhoe #1
rlcokc
After much discussion and research I went to my local kubota dealer to buy a backhoe. Thought I narrowed it down to Bh76 or Woods BX70 to BX80. Some had said the 80 was a little much for the 7800 and one of the sales guys agreed. The other said I would have no trouble with the 80. I had decided that was the one for me--they thought the woods a better buy for the money than the BH76--when he pointed out that he had a new woods 7500 which they had been outside and paint faded but brand new with warranty. The BX80 was $6500 installed with 4 point submount frame and he would sell the 7500 for a thousand less. The 7500 is a 71/2 foot reach--in between the 70 and 80. Seemed a perfect compromise to me and so I bought it. My understanding is the specs on the 7500 is pretty much between the 70 and 80 and may be a better fit for my tractor. Doesn't have the curved boom but I can do without for a thousand bucks. The paint is faded but the backhoe has never been mounted and no rust. What do you think? Good/bad decision--I can probably change my mind if I move fast.
   / B7800 backhoe #2
I would be wearing a $1000 smile! As long as the one you bought came with the 4 PT mount.
   / B7800 backhoe #3
There is the catch magicheater, I think the 7500 comes with a full subframe that has to come off each time........ not sure the extra hassle, and storage space would be worth it to me........ but that is just me.
   / B7800 backhoe #4
I hear ya, I am in the process of modifying a full subframe that will have to come off each time. Sold a 3PT unit and found this one. I tend to plan more with attachment usage. Convenience is nice but in the end you pay for it one way or another. I am not too inconvenienced when it comes time to change a 3PT attachment. That's life with a tractor. All of us probably have a favorite combo for the tractor. I have mine and I'm sticking to it as it has proved itself through the years.
   / B7800 backhoe
I thought I was told the 7500 used the same subframe as the newer BX80--anyone know if that is true? I would not want to take subframe off every time I remove backhoe altho don't think I will remove very often. Don't guess it would really matter that much to me but would like option of removing without removing subframe.
   / B7800 backhoe #6
Hi guys I put a bh80 x on my 7800 with full frame the machine handles it with no problem
   / B7800 backhoe #7
Here is where Woods lists the subfame mounts for the various backhoes, and tractors. I didn't see a 4 point mount for your tractor, but I haven't finished my coffee yet either. :D
Woods Equipment Company - Manuals
   / B7800 backhoe #8
Recently bought a b7800 with a woods 7500. I'm brand new to BHs but my engineering sense clearly supports the benefits of a subframe. The jolts and stresses of normal BH use are very high and just a 3 pt mount would worry me. Somewhere I read about a tractor with a just 3 pt BH literally breaking in half. Not sure its true but I can see (and have felt) forces that the subframe counteracts as a lever. It would also appear the subframe types allow more room for pto operated hydraulics. Beleive this allows for slower engine RPMs and greater efficiency. Again just a newbies .02.
   / B7800 backhoe #9
I have a B7800 with a Woods 7500 mounted on the sub-frame. The backhoe is a good match for the B7800. I do wish it had more power, digging in the hard soil in my area can be slow with the 7500.
Originaly I had the rear tires on the 7800 filled, I found that the tractor and backhoe was too heavy with the tires filled and drained the tires. I'm much happier with the tires drained.
   / B7800 backhoe
For you guys with th 7500 backhoe on the B7800 how difficult is it to remove the backhoe? Does the subframe have to come off to remove backhoe?
   / B7800 backhoe #11
The newer 4 point mounts use a full subframe too, but most of the frame remains on the tractor when the backhoe is dismounted. They are designed for MMM, and 3 point use, and are much easier to remove / replace.
   / B7800 backhoe #12
It's been pretty much determined that the "breaking in half" is more urban legend. The Kubota "3pt" BH uses a very beefed up toplink.
My BX70 will pretty much haul my B7610 all around. A good curl on the bucket will lift the FEL with my box blade chained on it a foot off the ground in a heartbeat. I'm sure it would overstress a 3pt.
If the OP is going to use a BH a lot I'd go for the BX80. My salesman was trying to talk me into a B4672, and I'm glad I went for the extra foot of reach with the BX70.
   / B7800 backhoe #13
I'm 99.5 percent sure the new style (current) four point subframe for the BH70X and BH80X fits the 7500. I would check to make sure they are installing the hoe using the four point mount, not the old style ladder subframe that used to come with the 7500 (as Chuck suggested). For a thousand dollar savings, you should be very happy with the 7500. I'm one of the guys who feels the BH80X is a little over-kill on the 7800. Not that its a huge deal....... but i think the BH70X is a better fit for the B series Kubota. With the 80X on my 3030...... the front tires will come off the ground going up hill with an empty bucket.
2014 International Maxxforce DT (A53317)
2014 International...
2014 FORD F-150 STX EXT CAB TRUCK (A60430)
2014 FORD F-150...
2015 CATERPILLAR 308E2 CR EXCAVATOR (A60429)
2015 CATERPILLAR...
2015 Doosan 750 CFM Mobile Air Compressor (A59228)
2015 Doosan 750...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
