B7800 b2910 frankenstein questions
   / B7800 b2910 frankenstein questions #1
Nicb7800
Salt lake city Utah
Kubota b7800
Hello
I have a 2007 kubota b7800 that was burned up pretty toasty in a barn fire. It burned everything plastic, rubber, paint, etc. so as you can probably tell it would have probably been a better idea to just take it to the dump. Lol I was able to get the motor to run and the hydrostatic works also, but it was going to cost a arm and a leg to put it back together even if I retro fitted pretty much everything. I was able to round up a 2001 b2910 and I am almost ready to start my project taking two and trying to make one. I understand there are a lot off differences but also I understand they are somewhat the same. Most people might be thinking why waist your time, me I like doing stuff like this, and it makes it even better sense the b7800 only had 178 hours on it and a loader and a backhoe attatchment. So if anybody out there might have anymore knowledge about maybe were I might run in to some problems on this please give me your thoughts. :) I will try and post pictures from the beginning to the end once I get it started, thank again for looking. Nic
   / B7800 b2910 frankenstein questions #2
Hello
Looking forward to your project reports. You may be able to install the mid pto, 3ph and position control from the B2910 on the B7800.
   / B7800 b2910 frankenstein questions #3
What is wrong with the B2910? Personally I'd just use that and not worry about the B7800. Even if the B2910 had 2000+ hrs it would still probably be more reliable than the B7800 motor/trans/hydraulics that went through a fire.
   / B7800 b2910 frankenstein questions #4
b2910, b7800- same pto hp, engine (bore stroke), displacement, engine hp, rpms, torque, fluid capacities, clutch, tires, power steering, brakes, hydro tran, pump cap., lift force.
differs in 3ph control (b2910=position, b7800=1/4" valve), weight (b2910=1763lbs, b7800=1740), b2910 telescoping 3ph, b7800 turnbuckles.
like you are thinking, lots of parts should be interchangeable. good luck with your project and most important, enjoy it.
Thank guys I will be getting the 2910 on Monday so I will let you no when my adventure begins. Thank nic
Bad Boy 31HP Pro Series Mower (A50514)
Bad Boy 31HP Pro...
2020 J&M 1151-22T Classic Grain Storm Grain Cart (A50657)
2020 J&M 1151-22T...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
2013 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2013 INTERNATIONAL...
2020 KUBOTA RTV...
