I'm considering my 1st tractor and cant decide what to buy. I have a couple acres of wooded hillside and 6 acres of relatively flat wooded/grass mix that I want to do general landscaping/cleanup/path building work on. I like the size/stability of the 7610 but worry about the loader lift capacity and weight for moving/boxblading logs/material. The 7800 is taller/longer and feels more tippy just sitting on it on the lot but hard to tell if it is in reality. The 7610 rear wheels can be moved out to the same width as the fixed width 7800 so seems more stable. In addition to the larger weight/loader capacity and much higher loader lift height, I can get the 7800 with a skid steer quick detach style bucket that can be swapped for pallet forks and grapple type front implements which I really like for possible future use. Anybody have any experience with these issues? Any input would be appreciated.
The only other tractor I'm considering is one of the new 27hp TYM K2 which seems to be the perfect mix of weight/size/lift capacities/skid steer bucket. Of course, it isnt a kubota, which is the big problem.
