B7610 remotes (also applys to B7510) with pictures.
   / B7610 remotes (also applys to B7510) with pictures. #11
I can't seem to get the pictures in this tread? are the links broken again?
COMunistCAST made me turn off my web server that I was running at home. Apparently, you're not allowed to run them on a residential account.
Here is a link to a the original post and all the pictures as posted on my COMunistCAST web space:
B7610 Remotes.
I'll convert this to a the proper format to display here and add it as a post.
Here is the hydraulic top link:
(click on any picture to see a larger image)
I also now have the B2910 type telescoping stabilizers (which were not
on yet when I took these pictures).
If you don't home remotes yet, here are some pictures that might help:
Hydraulic block location (FEL will be connected here):
The connection toward the front of the tractor is the pressure line,
the one toward the rear, is the power beyond return from the FEL, which
feeds the 3PH.
Here is the tank return line, which is just behind your reverse pedal:
The fittings are JIC-6 (pressure) and JIC-8 (return). Here is the TEE
that I used to tie in the tank return from my remotes valve:
And this elbow:
I used 3/8" NPT hoses from Surplus center, and the following adapters
to connect to the hydraulic block:
The 90 degree bent tube JIC-6 elbow came from discount hydraulic hose,
as did the 3/8" NTP to JIC-6 adapter.
Up at the loader valve:
Here you can see the power beyond return hose coming back from my
remotes valve to the hydraulic block. The hose that ran from the power
beyond port on the loader valve was removed, and replaced with a longer
hose going to the pressure port on the remotes valve.
Here is the new hose connected to the power beyond port of the loader
valve:
Here is the return hose from the remotes valve teed into the tank
return from the loader:
Remotes (with high tech "temporary" mounting bracket):
To see all pictures that I took while doing this, see here:
http://home.comcast.net/~jay.snyder/Tractor/B7610-remotes/all.html
   / B7610 remotes (also applys to B7510) with pictures. #14
Thanks thats perfect. I was following the lines from the power beyond from the loader and it looked like it was going to the rear axle tank. I went back to check your pictures they were gone. Thanks for the repost and all the work you put into documenting your install.
You're very welcome. I've gotten a lot of good information and help here, it's my way of giving some back.
The power beyond from the loader goes to the pressure input of the valve for the remotes. The line at the rear axle tank is the tank return lines of both valves.
   / B7610 remotes (also applys to B7510) with pictures. #16
i really like this setup. thanks for the pics i have been looking into this and slowly gathering parts. what are some uses everyone has been using their rear remotes for?
T-N-T (top-n-tilt).
I hope to be adding power angle to my back blade before this coming winter.
   / B7610 remotes (also applys to B7510) with pictures. #18
yeah the power angle on the back blade is prob first on my list.
Vermeer 554XL Round Baler (A50774)
Vermeer 554XL...
Chisel Plow with Cultivator Sweeps (A52128)
Chisel Plow with...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51243)
2021 MDB TF150R...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
74in FEL HD Round Back Bucket (A52128)
74in FEL HD Round...
Homemade Trailer (A50322)
Homemade Trailer...
