B7610 Rear Worklights
/ B7610 Rear Worklights #1
Killer_B
Platinum Member
Kalamazoo Michigan
John Deere 3320
I recently added some floodlights to the rear of the tractor using home made L brackets fastened into the existing side light brackets. The lights are fed by a relay, which is wired into the headlight switch. When the headlights are turned on, the rears also come on.
Photo attached.
Close up of bracket.
Back up shot.
/ B7610 Rear Worklights #4
Looks great. That should shed some light on the situation!
/ B7610 Rear Worklights #5
Nice install B,
Let me ask ya, I just got my 7610 and it has a backhoe on it so I was definately looking into some rear lighting. 2 questions: What type of lights are those and did you have to upgrade your alternator?
My biggest complaint of my new tractor is lack of seat time. Yes, you could say I'm "all hopped up on tractors" now.... /forums/images/graemlins/smirk.gif
Mo,
I got the lights here http://www.awdirect.com/awdirect/finditem.cfm?itemid=6119
I did upgrade my alternator from the 14 amp to the 40 because I also added two 100 watt front facing lights. See this thread. But I think these lights are only 35 watts each. So if this was all the lighting you added, the stock alternator will be fine.
Ditto the seat time comment!
2014 Freightliner Bucket Truck (A63689)
2014 Freightliner...
Cattle Feeder (A65640)
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
Morbark 30/36 Wood Chipper OFFSITE (A62613)
Morbark 30/36 Wood...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
2007 Talbert T4BDW-45-HRG-1-T1 45 Ton Detach (A62679)
2007 Talbert...
