B7610 rear wheel noise fix
   / B7610 rear wheel noise fix #1
digger2
n.e. pa.(lycoming co.)
kubota B26 TLB,former B7610 owner
just in case anybody has a hard "creaking" noise coming from the rear wheels
of their B7610 or similar machine w/the hex shaped rear axles that you can widen the wheel spacing on,before you take it back to the dealer($$$) pull
the wheels and flanges off,and put some anti-seize on the axle and the inside of the flanges,then reassemble.It worked for me,no more "creaking" noise.I
have to do this about every 6 months.I think it may have alot to do with the
950# woods bh hanging off the back.This could be "old" news but just in case
it could help somebody.
digger2
   / B7610 rear wheel noise fix #2
With me it was because the the wheel had loosened off a little bit. I have to tighten the bolt on the inside that holds the wheel on to the axle every 3 months or so.
   / B7610 rear wheel noise fix #3
Yea I get this too on my b7500 - I just slip my arm in there with a ratchet every couple months and tighten them up and the noise disappears. Can be done pretty quickly and easily.
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
2025 GIYI Skid Steer Plate Grabber (A50322)
2025 GIYI Skid...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
2013 CAT 950K WHEEL LOADER (A50854)
2013 CAT 950K...
