B7610 HSD - 2nd Rear PTO speed
   / B7610 HSD - 2nd Rear PTO speed #1
dholly
Platinum Member
Fingerlakes Region, Upstate NY
B7610HST
Anybody use it?
I.e., my B7610HSD Operator Manual states:
Rear PTO speed #1: 540rpm pto @ 2600rpm engine
Rear PTO speed #2: 960rpm pto @ 2554rpm engine
I know some folks just want to throttle down with a higher PTO speed to save fuel cost running a rotary cutter for example, but is there any downside basing the operating speed of an implement on something other than 540? Is that non-standardization considered blasphemous? /forums/images/graemlins/shocked.gif
Too many power outages and lotsa talk the past few years about PTO gennys and projects convinced me to pick up the el-cheapo 10kw gen head. Which, as a PTO genny, would require a 540>3600 = 6.7:1 increaser. Previous discussions say finding this ratio gearbox is like finding a needle in a haystack. After looking for a while, I agree (if you found a source, please share).
So why not just run off the 2nd PTO speed of 960 at recommended engine rpms? 960>3600 makes for an even 3.75:1 increase and it sounds like there may even be a few PHD and RC gearboxes with that ratio floating around. If nothing else, makes for a better selection/price of pulleys and/or sprockets. Comments?
Anybody actually finish a 3-pt HF pto gen? I built a 3-pt frame for the gen head, pillow blocks, pulleys etc., then ran into the attached pic on www.MachineBuildersNet.com. Now I really like that simple frame design for it's smaller, compact storage size, although I think I want to stick with cogged belt pulleys vs. chain sprockets. Thanks.
   / B7610 HSD - 2nd Rear PTO speed #2
I also would like to know if anyone has tried this?????
Or, maybe has something to add.
frankc - the PTO is there to be used at either speed. Designing to a non-standard (non-540rpm) PTO speed just limits the gennys usability to your own tractor. That may or may not be a big deal to you but I prefer the flexibility of being able to swap onto any tractor (with the proper shaft). However, if it costs twice as much to do at 540, well, I guess the neighbors are going to be out of luck 'cause I dont lend my tractor out. /forums/images/graemlins/wink.gif
BTW, I've only found one 1:1.375 hydraulic pump drive increaser that might be made to bolt-on the gen head with a custom adapter plate. Unfortunately, it cost $359.91 + UPS ground $30.00 = Total $389.91. Part No. B9212 from bare-co.com
Pulleys are looking a whole lot cheaper which, of course, was the whole idea originally...
2014 Dynapac CC4200 Tandem Vibratory Roller (A51039)
2014 Dynapac...
2016 Poulan Pro PP19A42 42in. Riding Mower (A49346)
2016 Poulan Pro...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
DOOSAN G25 GENERATOR (A50854)
DOOSAN G25...
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
2022 Continental 16ft T/A Enclosed Trailer (A49461)
2022 Continental...
