B7610 Hour meter on tach -- is it RPM based, or time based?
   / B7610 Hour meter on tach -- is it RPM based, or time based? #1
jas67
Platinum Member
Central PA
Kubota B7610 + Kubota G1800-S
I've only had my B7610 for a short time, but today, I noticed that I think the hour meter (which is in the tach) is based on RPM (which makes sense for maintenance), instead of clock time. I came from a B7100, which had no tach, so the hour meter was a basic hobbs-styled that just measured time.
I had 132.6 when I start working this morning at around 9:30am, and at noon, have just 133.5. I wasn't running it the whole two hours, but I'm pretty sure I was running it for a good bit more than 1 hour. I was mostly pulling my landscape rake, so I was running at 1500 RPM (PTO power is 2600 RPM).
Thanks,
Jay
   / B7610 Hour meter on tach -- is it RPM based, or time based? #2
My bx24 is time based. And usually when I'm on my tractor, I tend to lose track of time which can equate to either more or less time than I think it is :D.
   / B7610 Hour meter on tach -- is it RPM based, or time based? #3
My B7800 is RPM based (the tachometer/hour meter runs from the engine via a flexible speedometer-type cable). I suspect yours is too.
   / B7610 Hour meter on tach -- is it RPM based, or time based? #4
very good to know, thanks for this info!
   / B7610 Hour meter on tach -- is it RPM based, or time based? #5
This brings up a good point. I may log and time hack some operations to check that. I have actually left it running when I went to lunch.
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2003 - 1890/1910 Air Seeder and Air Cart (A51039)
2003 - 1890/1910...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2019 VOLVO VNL760 TANDEM AXLE SLEEPER (A51219)
2019 VOLVO VNL760...
1982 TANDEM AXLE CEMENT MIXING TRAILER (A50854)
1982 TANDEM AXLE...
