B7610 fuel filter
   / B7610 fuel filter #1
John762
Tennessee
Kubota/7610
Can anyone give me the part number(s) and tell me if there is more than one fuel filter?
   / B7610 fuel filter #2
If you check out Messick's website under parts and what fits my tractor .
Kubota B7610 Parts
hope this helps
   / B7610 fuel filter #3
There is only one filter, located on the right hand side. When you remove it, it has a check valve that automatically shuts the fuel off, unless your fuel level in the tank is higher than the little fuel return hose, in which case fuel will run out of the small hose when the filter is removed.
   / B7610 fuel filter #4
For the part number, there is a Quick Reference Guide on Kubota.com under Parts. It has some holes, but you can certainly find out the most common maintenance parts.
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
2019 UTILITY 53X102 REEFER TRAILER (A52576)
2019 UTILITY...
JOHN DEERE 9R640 LOT NUMBER 252 (A53084)
JOHN DEERE 9R640...
BESTWAY AG VSK50 LOT NUMBER 105 (A53084)
BESTWAY AG VSK50...
