B7610 converting to telescopic stabilizers
   / B7610 converting to telescopic stabilizers #1
WV B7610
I remember seeing posts in the past regarding a parts list, pictures and cost to convert a B7610 from chains to telescopic stabilizers, but all of the links I can find now seem to be dead.
I know TractorSmart.com was one of the parts sources, but all I can find listed there is filters. (Maybe I just need to skip their web site and call them.)
Can someone point me in the right direction?
(v8dave, are you out there? I know you posted a thread on this topic at one time.)
Any help would be greatly appreciated.
Thanks in advance.
Mike
   / B7610 converting to telescopic stabilizers #2
I own a B7510, you should be able to go to your local dealer and get the required parts. When I purchased my tractor I had the stabilizers swapped out with no additional costs.
   / B7610 converting to telescopic stabilizers #3
Are you sure it wasn't a B7800? (worth a search...)
   / B7610 converting to telescopic stabilizers #4
You can easily do it on a 7610. I've done it to my 2410, and believe me, it's worth the trouble. It's easy to do and the parts will run in the neighborhood of $100. Call tractorsmart, he already knows what you need. I'm sure Messick and Carver do as well and have packaged the parts many times. Have them pull the parts book on a B2710/2910, everything is listed there for your 7610, no modifications needed, they fit right on.
   / B7610 converting to telescopic stabilizers #5
This may get you to the appropriate page that explains the three point link arms replacement. This worked on my B7610. I hope this helps.Great upgrade from stock turnbuckle setup. Update: P/N 02174-50160 qty 2 $1.50, 04512-60160 qty 2 $.40, 04015-50160 qty 2 $2.02, 6co70-65310 qty 2 $63.52, 6c070-65320 qty 2 $32.58, 05122-61245 qty 2 $2.66, 6co70-65350 qty 2 $3.12, 6co70-65333 qty 2 $32.58, 05122-51235 qty 2 $3.56, 04011-50120 qty 4 $.80, 05511-50425 qty 4 $.24, 6co70-65340 qty 2 $2.88, 05515-61000 qty 2 $.96, total $146.82 plus tax.In my case total was $154.52 .FROM KUBOTA DEALERSHIP!!
http://www.tractorbynet.com/forums/...this in it will take you to the install link.
   / B7610 converting to telescopic stabilizers #7
Mike -
I made a PDF (Adobe Acrobat) from my invoice from TractorSmart (ca. 2005 - prices likely different!) - in reply to the same question in another thread (separate from V8Daves' original....) - but I can't seem to find that one either... :D
I think this list contains the same part numbers as what Maxqwest posted - only I think some of the part numbers come in "packs of 10" - rather than individual parts .... just something to look out for when ordering.
Hope that helps,
Dan
  • B7610 Telescoping 3PH Arm Parts.pdf
Guys..
Thanks for all of the replies. I really appreciate it.
I broke down and emailed Tractorsmart after posting my original message the other day. I got an immediate reply from Ronnie with a quote for $128.67 (including shipping). I called him the next day and placed the order.
The parts arrived yesterday and I installed them today. What a difference!! Now if I could just replace the cotter pin style adjustment pins with the ball-detent type I've seen elsewhere... Hmmm... I guess I'll have to give Ronnie another call.
Thanks again to all that replied!!!!!!!!!!
Mike
P.S. Nice B7610 pictures/web site Dan! AND I like that 3pt hydro top link! I must have one! There goes more money....
   / B7610 converting to telescopic stabilizers #9
Based on information from this forum and this thread in particular I decided to install the stabilizer upgrade to my B7610. It was very easy (took maybe 20 minutes). And as much as I am changing 3 pt implements, I should have done it a long time ago! Definitely worth it in my opinion.
Dave
   / B7610 converting to telescopic stabilizers #10
I don't use the hairpin clips anymore on the adjustment pins on my B3030. The pins are quite a bit longer than they really need to be so I figured I would have to hit one heck of a bump to bounce them out of the holes. So far, so good. Lot's easier to adjust the links if you don't have to mess with the clips. Not necessary IMHO.
2015 CAT 573c Fellerbuncher Cutter (A48836)
2015 CAT 573c...
Rhino 156 Chisel Plow - NO RESERVE SELLING ABSOLUTE (A51039)
Rhino 156 Chisel...
2004 FREIGHTLINER COLUMBIA 112 MID-ROOF SLEEPER (A50854)
2004 FREIGHTLINER...
2017 DITCH WITCH RT30 RIDE-ON TRENCHER (A51242)
2017 DITCH WITCH...
2017 Ford F550 4x4 Bucket Truck - 45FT Terex TL40 Boom, Powerstroke Diesel, Utility Bed, 54K Miles (A51039)
2017 Ford F550 4x4...
2013 UTILITY VS2DX 53FT DRY VAN TRAILER (A51222)
2013 UTILITY VS2DX...
