B7610 Block Heater
   / B7610 Block Heater #11
Just ordered my B-7800. The dealer threw in the block heater for free. I also have block heaters in all my vehicles. At -40F, it's worth every penny!
   / B7610 Block Heater #12
herringchoker said:
I installed a block heater on my B7800 before the first winter (just because I think it is much easier on any engine to start it warm). The engine had a threaded (NPT) plug, but I needed a bushing to adapt to the smaller thread of the (aftermarket) heater. It works great.
Can you post a photo of the plug location and the heater install? How long did it take you to retrofit it?
Thank you
   / B7610 Block Heater #13
Kubota block heaters for the B7510 & 7610 seem to be only for the freeze plug, which I did not care for. I went for an after market, 1 inch NPT, which screws directly in the left side of the block. 400 watts. 1\2 to 1 hr the block is nice and warm. Just great.
   / B7610 Block Heater #14
Based on my expeience with my new B7800 I reccomend the block heater. As a matter of fact the dealer in northern Michigan where I bought the B7800 puts a block heater on every Kubota they sell.
My B7800 sits in the garage beside my wife's car and my truck. Just like the block heaters on the car and truck the one on the tractor makes a huge difference in how fast the engine, hydralics and transmission warm up and are operational. I don't like being in the garage with the tractor running (the garage door is open) so I like to gret it outside asap.
Anyone ever try one of these from TSC? -
detail.asp
Saves fuel cost. Helps engines start quicker and run smoother. Saves engine wear. 200 watt, 120 volts. Thermostatic controlled. Has the widest variety of uses-will stick to any metal surface such as oil pans, motors, water container, hydraulic reservoir, 2 cycle engines. CSA approved.
   / B7610 Block Heater #15
Thanks, there is a new TSC not too far from me in New Milford, CT I'll have to check it out. My wife is wondering what she allowed me to get into when I recently ordered a new B7800!
   / B7610 Block Heater #16
bialecki - It's been over 2 years since I did the install, and I didn't take any pictures of the progress. It is a really simple job - it took no more than 1/2 hour. First, drain the rad. Remove the threaded plug from the block, install the heater into the bushing and then thread the bushing and heater into the hole in the block where the plug came out. Plug the cord into the heater and route the cable where it is convenient to plug into. Fill the rad, and you're done.
Attached is a fuzzy picture I just shot. The block heater is on the left side of the engine behind and above the oil filter, behind and below the alternator and ahead and above the starter. The heater (with its orange/red electrical plug) is in the centre of the photo and has a brass body. It is threaded into the iron pipe bushing, which is threaded into the block. (The black hose running vertically to the right of the block heater is the supply hose for the cab heater.)
I got the block heater from an automotive parts jobber. It was the part listed for the B7800. I forget the brand, but I'm guessing it is Temro since that is a line the jobber handles. I got the pipe bushing at a hardware store.
Hope this helps.
   / B7610 Block Heater #17
I have a dealer installed block heater, so I would think it pretty standard.
When I go to Wyoming I don't have electricity, but I do have a Generator that I can run at any time.
About how long would I need to plug the block heater in to get the block warm??
Low tempature would probably be around 0 to -10.
   / B7610 Block Heater #18
Ever think about using a small portable magnetic block heater? I don't think you'll need a heater at all, but if you think you do, this might be an option. I have one, though I must admit I have never had to use it. I came close a few times, but even when it was zero out my older, 1983, b7100 started, though I had to activate the glow plug a little longer than usual.
Teach
   / B7610 Block Heater #19
chuckcoug - I'm not sure with those temps ( I keep my B7800 in an unheated garage), but if it is out of the wind I think 1 hour should do it.
   / B7610 Block Heater #20
herringchoker: Thanks for the info. That is about what I was thinking. I wish I had a garage, but this is in the middle of no where. Basically, no water, no electric, no phone. Just mother nature and you. The cabin is over 80 years old and still standing strong. Surprising with all the wind Wyoming has.
2022 PETERBILT 579 DAY CAB (A50854)
2022 PETERBILT 579...
2016 KENWORTH T660 SLEEPER (A50854)
2016 KENWORTH T660...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A51039)
2019 New Holland...
1998 Ford F800 2,000 Gallon Water Truck (A49461)
1998 Ford F800...
2002 International 4400 SBA 4x2 Flatbed Truck (A49461)
2002 International...
2011 JCB 541-70 TELESCOPIC FORKLIFT (A51242)
2011 JCB 541-70...
