B7610 Block Heater
   / B7610 Block Heater #1
Dascro
SW Pennsylvania
Kubota B7610, Cub Cadet 1450
Working through the decision process on trading the ol' BX on a new B7610. One thing I have been considering is the need of a block heater. I live in south-western PA. Never had any real problems starting the BX on cold winter mornings, but the B7610 is a bigger engine. Any opinions?
Also, does anyone know if there is a threaded plug on the B7610 engine block for the block heater.
Thanks much for any input.
Dascro
   / B7610 Block Heater #2
I'm in Northeast Ohio and have a B2910 - had no problems whatsoever starting it last year after it sat outside overnight with the low in the teens. Just hit the glow plugs for about 10 seconds - it chugged for a bit (minute or so) after it started till it warmed up a little. Run Power Service in my fuel.
Having said that I have picked up a block heater for it ... but haven't got around to installing it.:D
Thanks rswyan.
And probably very good advice Egon!!
Do either of you know if the block heater threads into the B7610's block?
Dascro
   / B7610 Block Heater #5
I have a b7500 and live in upstate NY. I have never had trouble starting it in the winter. Low temps around zero...a few cranks and she starts up. I do store it in a barn, but there is no heat in there.
   / B7610 Block Heater #6
I'm 99% sure the block heater screws into the block on a 7610. You're dealer will know. They're pretty inexpensive, I would guess you're dealer might throw it in on a trade-in deal.
   / B7610 Block Heater #7
Sorry, not sure, had mine installed prior to delivery. Necessary? Probably not, but it's cheap enough to make sense if your area regularly sees below zero or extended single digit temps. For the really cold mornings, I park in a unheated garage and plug into a wall timer. It does turn over a lot easier using the heater and synth oil. The real benefit IMO, is that the tractor warms to operating temps much quicker. I recommend the big alternator kit as well.
   / B7610 Block Heater #8
If it won't easily fit into the block install an inline heater on the bottom rad hoze. Six of one and half a dozen of another. They both work equally well.
Thanks for all the great input and information.
I appreciate it!! I am calling the dealer today to see what they will do on installing the block heater as part of the package.
Dascro
   / B7610 Block Heater #10
I installed a block heater on my B7800 before the first winter (just because I think it is much easier on any engine to start it warm). The engine had a threaded (NPT) plug, but I needed a bushing to adapt to the smaller thread of the (aftermarket) heater. It works great.
1998 Dorsey Trailer, VIN # 1DTP16K29WG052604 (A48836)
1998 Dorsey...
2019 BOBCAT T770 SKID STEER (A51242)
2019 BOBCAT T770...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A51039)
Morooka MST 660VD...
2012 Mclaughlin V500LEHD Vac Trailer (A49461)
2012 Mclaughlin...
2017 F-550 Bucket Truck (A51039)
2017 F-550 Bucket...
1261 (A50490)
1261 (A50490)
