Ballast B7610 Ballast
   / B7610 Ballast
BW,
The Kub B series rear tires come with the two part valve stems designed for fluid filling. There is the fatter part that stays with the rim, and the skinnier inner part (called the core??) that threads off, leaving an open hole down the stem. This is what the filler adapter threads on to. It's a dirt simple operation.
Since WW fluid is not corrosive, I can't imagine what advantage a tube would be. If you're using calcium chloride, that’s another matter.
I used WW fluid straight up, undiluted.
I don't expect any huge difference in performance, just a little better traction in some situations.
Best of luck.
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2000 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A49461)
2000 Ingersoll...
Super Material Lift MH1000 (A51039)
Super Material...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2011 TROXELL 140BBL TRIAXLE VACUUM TRAILER (A50854)
2011 TROXELL...
Three Point Hitch Finish Mower (A48837)
Three Point Hitch...
