B7510
/ B7510 #1
B7510HSD
Kamiah,ID
Kubota B2601
Can anybody give me an idea what a B7510HST is worth it has 88 hours on the clock and has the Kubota 3point BH?? I am thinking about down sizing
to the BX25!
/ B7510 #2
to the BX25!
Down sizing??? Why?? hardly much of a downsize:confused2:
/ B7510
Mostly because of size for towing I think I could haul the BX easier behind the truck I have now which I can't haul the tractor I have without upgrading trucks!! I think my truck is only rated at towing around 5k which I think I would be pushing counting the trailer weight with what I have!
/ B7510 #4
I don't believe there is a significant difference (if any) in weight unless you buy the smallest BX. You might want to look into the secs a bit closer.
/ B7510
I was looking at the bx25 maybe I better check that a little closer! Thanks
/ B7510 #6
I agree that the weight difference is not likely to be significant. Those specs are readily available, but I think you'll find the two tractors to be within 300 lbs of each other, with similar equipment and attachments.
/ B7510 #7
I think you will find the weights are within 100#. The weights of the tractors alone are less than 50#. I am sure the loader and backhoe will be the same.
The only reason to change is if you have a desire for a new machine and there is nothing wrong with that.:laughing:
/ B7510
Thanks Guys I guess I will keep what I have after finding the specs some day I'll get a real truck that will pull it I would like to be able to odd jobs away from home with it!!
/ B7510 #9
The book lists the B7510 HST as 1367lbs for tractor alone. Add 400-600 more for the loader and what-have-ya.
The BX25 specs you can find on the Kubota site but I'd bet it is pretty close.
I'd say keep it unless you really don't like it.
/ B7510
No I have no problem with it I just thought the other one would be lighter for towing !
/ B7510 #11
Hi 7510...........I have 05 7510 with FEL and have been looking for BH.......thought maybe I had found it if you wanted to sell the BH separatelly but after reading the rest of the responses and your last one, guess that will not work....also noted you are a world away in Wash state. Out of curiosity is your BH the 4672 that Kubota says is what I need for mine?? Sorry to hear you are keeping it but if you change your mind, please give me a jingle. Thanks,
jayutilitytractor
Hays LT1 Tender (A61307)
Hays LT1 Tender...
Bushwhacker ST120 Offset Batwing Cutter (A64047)
Bushwhacker ST120...
2019 Jayco Octane T32H Toy Hauler (A62613)
2019 Jayco Octane...
SET OF (20) ACE CATTLE PANELS W/ CONNECTING JOINTS (A63569)
SET OF (20) ACE...
Club Car Golf Cart (A64047)
Club Car Golf Cart...
2020 INTERNATIONAL LT625 6X4 TANDEM SLEEPER TRUCK (A59910)
2020 INTERNATIONAL...
