B7510
   / B7510 #1
B7510HSD
Veteran Member
Kamiah,ID
Kubota B2601
Can anybody give me an idea what a B7510HST is worth it has 88 hours on the clock and has the Kubota 3point BH?? I am thinking about down sizing
to the BX25!
   / B7510 #2
to the BX25!
Down sizing??? Why?? hardly much of a downsize:confused2:
   / B7510
Mostly because of size for towing I think I could haul the BX easier behind the truck I have now which I can't haul the tractor I have without upgrading trucks!! I think my truck is only rated at towing around 5k which I think I would be pushing counting the trailer weight with what I have!
   / B7510 #4
I don't believe there is a significant difference (if any) in weight unless you buy the smallest BX. You might want to look into the secs a bit closer.
   / B7510
I was looking at the bx25 maybe I better check that a little closer! Thanks
   / B7510 #6
I agree that the weight difference is not likely to be significant. Those specs are readily available, but I think you'll find the two tractors to be within 300 lbs of each other, with similar equipment and attachments.
   / B7510 #7
I think you will find the weights are within 100#. The weights of the tractors alone are less than 50#. I am sure the loader and backhoe will be the same.
The only reason to change is if you have a desire for a new machine and there is nothing wrong with that.:laughing:
   / B7510
Thanks Guys I guess I will keep what I have after finding the specs some day I'll get a real truck that will pull it I would like to be able to odd jobs away from home with it!!
   / B7510 #9
The book lists the B7510 HST as 1367lbs for tractor alone. Add 400-600 more for the loader and what-have-ya.
The BX25 specs you can find on the Kubota site but I'd bet it is pretty close.
I'd say keep it unless you really don't like it.
   / B7510
No I have no problem with it I just thought the other one would be lighter for towing !
2001 Chevrolet Silverado 1500HD Crew Cab Pickup Truck (A51692)
2001 Chevrolet...
2014 Rockwood Premier 2317G 23FT S/A Pop Up Camper (A51694)
2014 Rockwood...
2006 Ford F-350 Forestry Dump Truck (A51692)
2006 Ford F-350...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
