B7510, L2800, or ???????
/ B7510, L2800, or ??????? #1
Niner
Hi Y’all.
For the last several years I have been using a 1947 John Deere “M” tractor for stuff around our 5 acre “homestead”. Grading the 150+yards of gravel drive, skidding downed trees out of the woods, etc. We have a very tiny yard, maybe ½ acre that gets taken care of by the old Murray rider. The rest of the “homestead” has been left natural with lots of very old hardwoods.
We recently purchased 45 acres in the next county over (VERY rural). I told the Mrs. that “Auntie M” just wouldn’t be able to handle the duties at “the farm” and we neeeeed to upgrade to a modern tractor with modern hydraulics. The “farm” is mostly wooded. There is a field (I’d say about 8 acres), and a series of small ponds along a creek. These are the areas that I will need to keep up.
Seeing as I am the Webmaster for our local 2-cylinder club (http://www.westga2cyl.com), I looked at the green machines first. I talked with them for several hours about a JD790 4x4 with a FEL. However, we also made a trip by the local Kubota dealer and I found that I really am attracted to the size of the B7510 4x4. I REALLY like the layout of the controls vs the JD. The Deere has six more horses, but the B7510 looks to be half the physical size. Something that I think will come in handy around those ponds. Plus I am kindof turned off by all of the plastic on the Deeres. My “M” didn’t get to be 58 years old sporting a bunch of plastic bodywork.
I have read elsewhere on this board about the L2800, and how it is just slightly bigger than the B7510 unit. I have called just about every dealer with 3 hours driving distance and NONE of them have an L2800 on their yard. Most said they “have them on order”. One dealer said that Kubota has quit making the L2800. Is there any truth to that? I sure would like to take a look at one next to a B7510.
Whichever I get, I plan to have it rigged with a FEL and ag. tires.
I already have a 5’ box and, a 5’ grader blade. I’ll need to get either a 4 or 5 foot brush-hog for that field. Also, should I get a tooth bar for the FEL? I understand they really improve the digging ability of an FEL bucket.
Thanks in advance for your replies to my ramblings
/ B7510, L2800, or ??????? #2
We have three L2800DT on our lot, we have the HST models on order, but are not going to receive those until probably May. As far as Kubota discontinuing that model we have not heard anything about that. I don't think they would be discontinuing models (HST verison) that they just introduced last fall and are yet to reach dealers.
/ B7510, L2800, or ??????? #3
Niner,
That is a huge question you just asked!
As far as the Kubota line up goes, I think you need to spend some more time on dealer's lots sitting on and sizing up the offerings. The L2800 is shown in the new brochure I just picked up at my dealers (along with the L3400 and another size I forget the number of) so it is still being sold.
Is money an issue? My gut is telling me I would want to go with a larger tractor than a B7510 if I owned over 40 acres to work it on...if I could afford to do so. /forums/images/graemlins/smile.gif
If you want something smaller than the L2800, you might consider a larger B series like the B7800 or B3030.
Me, I'd be looking at a L3430 or L3830 I bet. /forums/images/graemlins/smile.gif
Not sure this post is much help. But it sounds like you need to zero in as far as size goes, and the best way is to touch, feel and smell more tractors first hand, since it really comes down to what you personally will be most comfortable with on your new property.
/ B7510, L2800, or ??????? #4
If you are used to pulling some logs I think you would not be crazy about a B series tractor. The L2800,L3400 are mid way to the grand L series so I would consider these 2 models. They are the same physical size but for not much more money(tractor wise) the L3400 is much better more horse power 2 stage clutch for mowing I would seriously check this tractor out it sems like we have alot of similar property I would not go smaller.
2011 Freightliner M2 106 Medium Duty T/A Dump Truck (A61573)
2011 Freightliner...
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
2017 Ford F-450 Liftmoore 5000W 2 Ton Crane Service Truck (A61573)
2017 Ford F-450...
Titan Hydraulic Hay Bale Handler (A62613)
Titan Hydraulic...
(APPROX. 128) 1"X6"X8" PONDEROSA PINE (A64281)
(APPROX. 128)...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
