B7510: float detent
   / B7510: float detent #1
JCA
Maine
Kubota B7510
Hi folks. It has been a while.
My Kubota has only 66 hours on it, and the float position detent has just stopped working. I had some problems with it in cold weather last winter, but this isn't a cold-weather issue. it just pops right out of the detent. I think I hear a noise coming from the front part of the loader, but I'm not sure. Can anybody help with this?
Thanks,
Jim
   / B7510: float detent #2
Not sure if your valves are the same as mine or not (L4330), but on mine, the detent assemblies are two hex bodies about 4-5" long on the bottom of the valve. They tend to collect water, which can then freeze OR just rust/corrode the little detent balls/springs. At the dealer's suggestion, I simply unscrewed them (carefully watch for any balls that may fall out!) and them cleaned them with clean kerosine followed by a good wipeout, and a final rinse. Before I screwed them back on, I mashed a good fingerfull of grease into the detent balls and around the threads. They've worked perfect since.
2014 Chevrolet Express Van (A55973)
2014 Chevrolet...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56438)
2020 Westfield MKX...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
