B7500HSD with FEL
   / B7500HSD with FEL #1
Spud
Moncton, New Brunswick, Canada
2001 Kubota B7500HST
Hi
Anyone know what the length of a B7500HSD & LA302 Fel would be? I need to figure this out before I have a trailor made to haul the B7500HSD and Fel. Guess I should most likely add some length for a rototiller or backhoe also.
Spud
   / B7500HSD with FEL #2
Spud
Check out this thread on Trailer spec's. There is a lot of information on how to spec a trailer. My guess would be 16 to 18' by maximum width between fenders 7'6".
   / B7500HSD with FEL #3
I use a common style dual-axle trailer with a 16' x 6.5' floor. My B2150HSD w/FEL should be only slightly longer than a B7500.
The tractor/FEL/60" Landpride finish mower goes from the front rail to the rear edge.
The tractor/FEL/rotary mower hangs off the trailer by the length of the rotary mower's tail wheel.
I have had no problems with the 6.5' width; however, I did refuse to buy a new 6' wide finish rear-discharge mower because it was 1" too wide for my trailer (this allowed me to jump on a great deal on the used 60" side discharge Landpride mower).
Therefore...
Length: Get at least 16 feet.
Width: 6.5 feet should work for the rototiller and back-hoe. A 6' landscape rake or a 6' scraper blade should fit with narrow clearance. You probably shouldn't be using 6' mowers on the B7500 so that shouldn't be a problem.
Kelvin
2018 CATERPILLAR 320GC EXCAVATOR (A51242)
2018 CATERPILLAR...
2018 Ford F-150 (A51039)
2018 Ford F-150...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A51039)
2021 John Deere...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A50459)
2007 FORD F-750XL...
CAT 312C (A50854)
CAT 312C (A50854)
