B7500 won't stay running
   / B7500 won't stay running #1
Chucks
Stafford, VA
Kubota B7500 HST
I was mowing the pasture when my 5 year old B7500 (<200 hours) sputtered and then died. I tried to restart it, but no luck. It cranks and tries to start. I get some black exhaust smoke and it seems like it wants to run, but dies. I was thinking fuel problem of some sort, because it will crank and tries to start. The battery light flickers when I'm cranking. Anybody got any ideas before I call the dealer? Thanks.
   / B7500 won't stay running #2
I'm sure there are people better able to answer this, but I would check fuel filter, plugged screen in the fuel tank, bad fuel line, water in fuel. How was it running prior to stopping?
   / B7500 won't stay running #3
I would also suggest checking the fuel system and in particluar the fuel filter. If it's cranking and not starting and was getting the proper amount of fuel it should be white/grayish smoke. If it's only a little bit of black smoke and not starting I would suspect the system is starved for fuel.
   / B7500 won't stay running #4
While it could be something else, I think fuel is right on target.
Calling the dealer isn't a bad idea, but before you take it in and pay them to dig into it, drain your fuel tank and lines and put a new fuel filter in with fresh diesel. Won't hurt, and is a lot less than shop fees.
   / B7500 won't stay running #5
defiantly sounds like fuel, check the basics,
1/.fuel tap is on, if memory serves me correctly it is part of the fuel filter assembly on a 7500, should be straight down.
2/.take the fuel tank cap off and then bleed it, sometimes the breather in the cap gets blocked, causing a vacum in the tank
3/. make sure that it is diesel in the tank, not gasoline, (hvae seen it done many times)
4/.what is the fuel filter like, when was it last changed
5/.is there enough fuel in the tank, sometimes when you are on an angle the fuel will run away from the pick up, the bigger m series kubota's are good at this.
as a quick check,throw a new fuel filter on it, while the filter is off, turn the fuel tap on and check there is fuel coming through, then bleed the fuel system and try to restart, let me know how you go
Guys, thanks for the ideas. I definitely need to replace the fuel filter anyways. The tractor's 5 years old and never been changed. Fuel level's at least half fuel. I tend to think that if it's not a clogged filter, then maybethe fuel had water in it. anyway, I'll report backj when I figure out the problem.
Thanks again for your help.
   / B7500 won't stay running #7
Does this model have a fuse for the fuel solenoid? Just wondering, as I had what sounds to be the exact same problem and it was a simple blown fuse. Sorry if this doesn't help, but its always worth a look through the fuse box.
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2005 Mack CV713 Granite Truck, VIN # 1M2AG11C55M020965 (A51572)
2005 Mack CV713...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
