B7500 with BL2660 rear blower
   / B7500 with BL2660 rear blower #1
Anonymous Poster
Epic Contributor
Does anybody have experience with the B7500 using the BL2660 rear 60" snow blower. I am thinking of buying a B7500 and need to move Minnesota snow on my 4.2 acres. Also, I've seen a few negative comments on the deck-driven bagger for the B7500. I am currently looking at the B7500 with BL2660 rear blower and the LA302 front-end loader, and either the 54" or 60" mid-mount mower. I would appreciate any and all comments or suggestions.
   / B7500 with BL2660 rear blower #2
I have a B7500, but I never even considered pricing a Kubota blower. Most Kubota owners on this board limit their Kubota brand implement purchases to FEL's, MM mowers, and back hoes.
I don't know who actually designs and manufactures the Kubota blower, but I do know that Pronovost, Ber-Vac, Buhler/Farm-king, and Loft are all manufacturers that live in the snow belt. I would suspect that they would be significantly cheaper, also.
As for the mower, I opted for a 3ph, rear-discharge by Buhler/Farm-King. I used to a have a B5100E with a mid-mount. I admit that the mid-mount was probably easier to control, but I had problems with grass build-up (more related to side discharge than mid-mount). The 3ph mower can get under my spruce trees (really nice when you've got a sunburn /w3tcompact/icons/laugh.gif), connects/disconnects really easily, and can hook up to any standard, category I 3ph. Oh, and it does a fantastic job.
Thanks for the input. Yes, Farm King/Allied are common blowers here in Minnesota. I will check them out. Do you have a bagger implement for fall leaves, etc?
   / B7500 with BL2660 rear blower #4
I think the only way to collect debris with my set-up would be to drag a lawn sweeper behind the mower. The location of my property (very rural) allows me the option to not bother to pick up leaves. With the rear discharge mower, I can run them over until they're significantly mulched. If need be after that, backing up over them with the mower is a lot like using a leaf blower. I like to leave the grass clippings on the lawn. As long as they're not big and clumpy they do a fine a job of feeding the lawn.
2012 John Deere 7280R MFWD Tractor (A52748)
2012 John Deere...
1991 Peterbilt 378 T/A Dump Truck (A50323)
1991 Peterbilt 378...
2016 Nissan Frontier Ext. Cab Pickup Truck (A50323)
2016 Nissan...
Bobcat 709 Skidloader Backhoe Attachment (A50774)
Bobcat 709...
New 12x20 Steel Carport (A50774)
New 12x20 Steel...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A52748)
2016 KBH...
