B7500 Stalls w/load
   / B7500 Stalls w/load #11
wow...I don't know. Definitely sounds like an air or fuel problem - one or the other is being limited somehow. I doubt it has anything to do with your hydraulics.
Thanks Mike--went to the Kubota shop--they swear its fuel so I'll drain the take AGAIN--look for water--hunt for an additive to clear injectors--and keep finders crossed!! Cats are good for doorstops and Teriyake-did I say tha outloud!
O.K.--HERE'S THE SKINNY---DRUM ROLL!!!!!!!!!! Apparently when I changed the fuel filter I forgot to fill the filter and bowl before reassembling it to the tractor. Hence the Air in the fuel system***--So to fix the problem follow the rubber hose up from the fuel filter to a nut that is between two rubber hoses. 14mm box wrench loosen the nut--have someone crank(not start) the engine--I saw 6-8,9 small pinhead bubbles come out until it "cranked" fuel--tightened her down--NO Stall w/Load-runs great--just as it begins to snow again. If that didn't work next stop loosen an injector and crank it clear of bubbles.:)
   / B7500 Stalls w/load #14
Interesting............my 7500 has an auto shut off when you remove the bowl. By the time it is back in place the bowl is running over. Job done.
   / B7500 Stalls w/load #16
lloydtilton,
Thanks for posting this. Could be helpful for the rest of us in the future.
My posting was a thanx for those who offered a possible solution; an hopefully helpful to those who come after. Manually filling the filter bowl leaves a "bubble". Once you get one or two threads on the stationary lid(not a firm bite) there is (I'm told later) an auto fill aspect to the B7500 that will fill the bowl to a spill over--which is what you want to prevent a bubble in the system. Thanx to Mark for the tactful observation that all was well until IK laid my hands on it and to Back track all I touched--Thanks again!! Now--I need suggestions for a reasonabley priced B7500 shop manual. Let's seee what else I can break--Thanxx all--RJ
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2023 AVANT 735 COMPACT WHEEL LOADER (A51242)
2023 AVANT 735...
2006-2009 Ford 4x4 Pickup Truck Bed (A49461)
2006-2009 Ford 4x4...
AMCO F42B-3626CS 13ft Pull-Behind Wheel Offset Harrow Tiller (A49461)
AMCO F42B-3626CS...
2007 John Deere 4320 Cab 4wd (A51039)
2007 John Deere...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
