B7500 Rear Remotes
   / B7500 Rear Remotes #1
Glenn1
Bronze Member
Louisville, Ky.
B7500 Kubota
My dealer quoted me $700 for parts and labor for rear remotes. Two hoses and two connectors can not be that expensive. Does anyone know what is included in the kit and is the price normal?
   / B7500 Rear Remotes #2
Is that for one pair of remotes? Or two? And I assume it includes the valve? Price sounds about right for one, and a bargain for two I would think.
   / B7500 Rear Remotes #3
You are actually getting a valve, mounting hardware, connectors and 3 hoses.
List price on the Kubota kit from Tractorsmart.com for a 2 remote system is $870. Kit includes B7333, B7343, and B7393. Installation labor is extra. A single remote system would be $600 and is only the B7333.
You are getting a good deal from the dealer if he is using Kubota parts.
Thanks to all for the info. The dealer quoted a kit, I will check to see if it is for one or two remotes.
Your response has made me rethink my need for the rear remote. I am in the process of building a small backhoe attachment and want to connect the hoses on the rear of the tractor. Any thoughts?
   / B7500 Rear Remotes #5
<font color="blue"> I am in the process of building a small backhoe attachment and want to connect the hoses on the rear of the tractor. Any thoughts?
</font>
Yes...if you are wanting to power the backhoe you don't need the remotes, just a way to tie into the hydraulic system. On my B2910 Kubota, this is possible using a special block that costs about $60 more or less.
For a backhoe you would need to have the controls in front of you anyway, so the Kubota remotes would do nothing for you in that case.
I don't kow if the b7500 has a rear outlet block for hydraulics or not...but if not you could use the Power-beyond port of the loader control valve...
Just a couple thoughts that someone else can add to... /forums/images/graemlins/smile.gif
   / B7500 Rear Remotes #6
No rear aux hydraulic outlet block on any of the 7000 series Kubotas.
Remember that backhoes typically do not have a power beyond so the hydraulic circuit is diverted to the BH and the 3pt is disabled. Now if you have a pto driven backhoe then this does not apply.
I have considered a pto pump w/tank for $500. The company I purchased the kit from suggested using the tractor hydraulics to save money. It may be less expensive to go with a pto pump.
   / B7500 Rear Remotes #8
If money is your main concern then go with the pto pump and tank.
However, having rear remotes can be a big advantage since you can now have a hydraulic top link and/or tilt link. You will also be able to use a hydraulic chute rotator for a snowblower or any other implement that has hydraulics.
Rear remotes with a pto pump driven backhoe is the ideal situation.
The drawback to using rear remotes for the backhoe is that you will have to tie the actuating lever on one of the spools so that it remains open all the time with flow going in the correct direction. This generates a lot of heat which could lead to other problems.
Tractors that have backhoes that are run from the tractor's hydraulics are typically plumbed so that the 3pt is disabled whenever the backhoe is connected. This is done for safety reasons.
Thank you for the info, now it is decision time. /forums/images/graemlins/cool.gif
GENERAC MAGNUM LIGTH PLANT (A50854)
GENERAC MAGNUM...
C13 MOTOR (A50854)
C13 MOTOR (A50854)
PALLET OF AIR CHISELS (A50854)
PALLET OF AIR...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
Rhino 156 Chisel Plow - NO RESERVE SELLING ABSOLUTE (A51039)
Rhino 156 Chisel...
