B7500 Rear PTO
   / B7500 Rear PTO #1
rtrent
Orange County, NY
Kubota B7500
My rear PTO worked at one time, but I don't normally use it. Only the mid-PTO for mowing. I had a leak at the rear PTO shaft seal for a while and finally got around to replacing the seal. When I had it back together and checked everything, only the mid-pto works. Since I wasn't sure if it worked before the seal repair, I'm not certain if the problem pre-existed the shaft seal job. The PTO shifter moves smoothly into either PTO position and I can hear gears engage in either position, but only the mid-PTO spins. Since I didn't know if it was working just before I started I thought I might have screwed up, but there really isn't anything to mess up. Take the PTO cover/shaft carrier off, remove the old seal and replace. The shafts pulled out a bit with the cover, but they just go right back in place. Found a thread about rear PTO "linkage" adjustment on B7500 fixing a very similar symptom, but no details. Messaged member, but no reply. I can't see anything related to the linkage that would affect rear only and not mid-PTO. Does anyone know what/where the linkage adjustment is? Or any other suggestions? Thx!!
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
Corn Reel (A50514)
Corn Reel (A50514)
2014 INTERNATIONAL PROSTAR (A50854)
2014 INTERNATIONAL...
2015 John Deere 35G Mini Excavator (A49461)
2015 John Deere...
2012 SULLIVAN PALATEK AIR COMPRESSOR (A51222)
2012 SULLIVAN...
