B7500 no response from 3PH
/ B7500 no response from 3PH #1
Gunnahafta
Midcoast Maine
Kubota 7500 HSD
Yesterday I was working on my parking area with a 4' box blade enjoying my Kubota Therapy when I went to lift the blade and the lever went completely loose. (Luckily it was at the end of the day.) There is no resistance at all when I move the lever. The box blade has now turned into an unretrievable anchor.
There seems to be a missing spring, but when I looked under the seat where all the moving parts are, I can't tell what (if anything) is missing.
Did any of you have this happen to you and how can I go about fixing this? My gut feeling is that it's a simple fix, but I'm an optimist.
Or, can anyone take a photo of what it's supposed to look like down there so I can see what's missing?
As always, the TBN brain trust is very much appreciated!!!
/ B7500 no response from 3PH #2
I don't have access to a B7500 so I can't help you out w/a pic but you may try moving the lift lever while looking down into the area where it attaches to the rod or bracket that goes back to the HST and see where it's come loose. It could be something as simple as a screw down locking has come loose allow the rod to slip or a loose or missing clamp where the rod goes into the HST.
Perhaps someone w/a B7500/B7510 will see this post.
Good luck
Volfandt
2022 EZ-GO ELITE...
KUBOTA BX1870 TRACTOR (A65054)
KUBOTA BX1870...
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
2021 Ford Transit 350 HD Reefer Box Van (A64194)
2021 Ford Transit...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2019 Ford F-150 4x4 Pickup Truck (A64556)
2019 Ford F-150...
