B7500 no response from 3PH
   / B7500 no response from 3PH #1
Gunnahafta
Midcoast Maine
Kubota 7500 HSD
Yesterday I was working on my parking area with a 4' box blade enjoying my Kubota Therapy when I went to lift the blade and the lever went completely loose. (Luckily it was at the end of the day.) There is no resistance at all when I move the lever. The box blade has now turned into an unretrievable anchor.
There seems to be a missing spring, but when I looked under the seat where all the moving parts are, I can't tell what (if anything) is missing.
Did any of you have this happen to you and how can I go about fixing this? My gut feeling is that it's a simple fix, but I'm an optimist.
Or, can anyone take a photo of what it's supposed to look like down there so I can see what's missing?
As always, the TBN brain trust is very much appreciated!!!
   / B7500 no response from 3PH #2
I don't have access to a B7500 so I can't help you out w/a pic but you may try moving the lift lever while looking down into the area where it attaches to the rod or bracket that goes back to the HST and see where it's come loose. It could be something as simple as a screw down locking has come loose allow the rod to slip or a loose or missing clamp where the rod goes into the HST.
Perhaps someone w/a B7500/B7510 will see this post.
Good luck
Volfandt
2016 FREIGHTLINER CASCADIA TANDEM AXLE 6X4 MID ROOF SLEEPER TRUCK (A51219)
2016 FREIGHTLINER...
2019 Chevrolet Tahoe SUV (A49461)
2019 Chevrolet...
71053 (A49346)
71053 (A49346)
WEATHERFORD MP-10 TRIPLEX MUD PUMP POWERED BY A CATERPILLAR 3412 ENGINE (A50854)
WEATHERFORD MP-10...
2017 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A49461)
2017...
2014 MACK GU713 WATER TRUCK (A51243)
2014 MACK GU713...
