B7500 Hyd
/ B7500 Hyd #1
Anonymous Poster
Epic Contributor
Well, it finally came. It is now 8:30 P.M. I have owned my new Kubota for 2 hours. Already I have a question for my fellow Kubotians. When I start to drive in high range in foward or reverse I notice that the tractor will slowly start to move and then suddenly will slightly jolt to a faster speed and then act normally through the upper speed ranges. This does not happen in low range. I suspect this is the high range hydraulics cutting in. Any B7500 hydro owners out there with the same experience? JETHRO
/ B7500 Hyd #2
That's the neutral valves closing after pressure builds in the closed circuit loop. Less noticeable in low range but still there.
Translation: Normal HST operation./w3tcompact/icons/wink.gif
/ B7500 Hyd #4
I've noticed it - like a turbo kicking in. It's weird sensation when you're used to manual transmissions.
/ B7500 Hyd #8
Thanks, fishman. I spent more time undoing than doing./w3tcompact/icons/tongue.gif
Heavy Duty Power Line Winch (A65579)
Heavy Duty Power...
2022 EZ-GO ELITE...
2022 Timpte T/A Super Hopper Grain Trailer (A64194)
2022 Timpte T/A...
(INOP) INTERNATIONAL 1066 TRACTOR (A64278)
(INOP)...
New 1.5x27 Ratchet Strap (A65583)
New 1.5x27 Ratchet...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
