B7500 Hyd
   / B7500 Hyd #1
Anonymous Poster
Epic Contributor
Well, it finally came. It is now 8:30 P.M. I have owned my new Kubota for 2 hours. Already I have a question for my fellow Kubotians. When I start to drive in high range in foward or reverse I notice that the tractor will slowly start to move and then suddenly will slightly jolt to a faster speed and then act normally through the upper speed ranges. This does not happen in low range. I suspect this is the high range hydraulics cutting in. Any B7500 hydro owners out there with the same experience? JETHRO
   / B7500 Hyd #2
That's the neutral valves closing after pressure builds in the closed circuit loop. Less noticeable in low range but still there.
Translation: Normal HST operation./w3tcompact/icons/wink.gif
   / B7500 Hyd #4
I've noticed it - like a turbo kicking in. It's weird sensation when you're used to manual transmissions.
   / B7500 Hyd #8
Thanks, fishman. I spent more time undoing than doing./w3tcompact/icons/tongue.gif
2014 MAGNUM PRODUCTS LIGHT TOWER (A50854)
2014 MAGNUM...
Landoll Hauloll (A51039)
Landoll Hauloll...
FUEL TANK (A50854)
FUEL TANK (A50854)
BUSH HOG 32601 - 6' ROTARY MOWER (A51243)
BUSH HOG 32601 -...
MEGGER EZ THUMP (A50854)
MEGGER EZ THUMP...
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
