B7500 HST 4WD
/ B7500 HST 4WD #1
6shooter
Can anyone help me, this is the first time I have used this site and am in need of knowing about the rubber hose that goes through the frame broke on the suction line of my Kubota tractor. How do I get to that hose to replace it? What all do I have to remove? HELP
/ B7500 HST 4WD
/ B7500 HST 4WD #3
I do not know what hose you are referring to. What do you mean by suction line. More information please.
/ B7500 HST 4WD #4
/ B7500 HST 4WD
my husband isn't here right now but I believe it is the hose that holds the super udt fluid from running out, the tractor has a large mower deck on it, if you can help we sure would appreciate it as the hose cost is only 24.00 but for the dealer to put it on we won't even go there!!!
/ B7500 HST 4WD
/ B7500 HST 4WD #7
You must be talking about a FEL hose that is attached to the R/H side of the transmission.
/ B7500 HST 4WD #8
/ B7500 HST 4WD #9
There's a main hydro line that connects under the tractor, just a rubber hose with a couple of spring clamps onto a metal tube. I can't imagine it costing very much, the hydro fluid should cost much more since that hose is broke most the hydro fluid is out.
It's a good time to change hydro filters and clean the strainer too.
/ B7500 HST 4WD #10
/ B7500 HST 4WD
thank you everyone for your help, no the line in relatively inexpensive only $24.00, but couldn't figure out how to get it off and they want $58.00 hour to do it at the garage. That is a lot as we are in Pennsylvania.
/ B7500 HST 4WD
2018 Dodge 5500 Bucket Truck 4WD (A63689)
2018 Dodge 5500...
NorTrac Rake (A64127)
JOHN DEERE 8' OFFSET DISC HARROW (A64276)
JOHN DEERE 8'...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
