Snow B7500 and rear blade position in snow
   / B7500 and rear blade position in snow #11
cchoate,
Hey, simple, easy and it works! What more could you ask for?
Do you have any problem with snow packing around the wheels?
Could I ask where you got the wheels?
Thanks!
Mike
   / B7500 and rear blade position in snow #12
The wheel came from TSC and were $16 each I think. The weight of the blade keeps the wheels turning and they clean themselves. They swivel in any posistion so going forward or backward is no problem.
As you can see, I need a welder. Drilling holes and using bolts and nuts is sometimes not the best solution.
   / B7500 and rear blade position in snow #13
Shawn, I've tried skid shoes, but I really get better results just floating the blade in reverse.
   / B7500 and rear blade position in snow #14
Until the ground freezes on my gravel driveway, I put the blade in reverse so the cutting edge does not cut into the dirt. This works quite well! After the ground is frozen, I turn it around so the snow will fall off the blade better. The gravel never moves after it's frozen.
2003 Big Tex 10PI...
2008 Kenworth T800 Semi Tractor, VIN: 1NKDX4TX68R235070, Day Cab, Cummins ISX-600 Turbo Diesel (A59076)
2008 Kenworth T800...
2390 (A58376)
2390 (A58376)
1997 Ford F Series (A57148)
1997 Ford F Series...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2012 Western Star Trucks 4900 SA Truck, VIN # 5KJJALDV0CPBE2239 (A57453)
2012 Western Star...
