B7500 and plowing
/ B7500 and plowing #1
theboman
Grayson, KY
Kubota B7500 HST
Well hooked up my brothers only single bottom plow to my B7500 and after a few adjustments and a bit of learning I'm even more impressed with the power of the B7500.
Amazing little machines...
I usually just till my garden but after 3 years decided I may try turning it over and working up the deeper soil...not sure if it'll help but got a couple extra hours of tractor time.
I'll till the garden and lay off rolls this week and get some beans, corn, cucumbers etc in the dirt... SEEDS... I have a 1/2 lb of last years greenbean seeds will they still be okay to plant?
/ B7500 and plowing #2
INTERESTING! how aggresive did u have it set and what were the ground conditions? being it was your garden there pobably was no sod right? was thinking of getting one for my b2400 and wondered how that would do with a single bottom.
/ B7500 and plowing #3
</font><font color="blue" class="small">( SEEDS... I have a 1/2 lb of last years greenbean seeds will they still be okay to plant?)</font> I don't have extensive experience with it, but I've never had any luck with seeds that old. I think the manner in which they are stored has a lot to do with it. A more experienced gardener can say better than I. John
/ B7500 and plowing #4
Check your seeds for germination.
Take about 6 or or so, soak in water for several hours, wrao in damp cloth, place all in plastic bag and store in a nice warm spot. Check in about four days and following days to see if they have sprouted. Chances are they will be fine.
I've used seeds that have been many years older with no problem.
Egon
/ B7500 and plowing #5
</font><font color="blue" class="small">( I have a 1/2 lb of last years greenbean seeds will they still be okay to plant? )</font>
Like Egon, I've used seeds a lot older than that with no problem. When I planted, I put left over seeds in coffee cans with the lids on, and saved them for the following year.
/ B7500 and plowing
It's just good ole dirt, lots of clay in the mix. It brakes up okay, I'm sure a heavy dose of lime couldn't hurt and the past couple years been tilling under some winter wheat and adding leafs from the yard.
I'm sure I could have had it more agressive to throw the dirt, but it turned it over fine for me.
I know today I tilled it so to start the garden this week and it tilled easier than ever!
/ B7500 and plowing
</font><font color="blue" class="small">( Check your seeds for germination.
Egon )</font>
Thanks Egon.
You've inspired me. I'll run down to Lowes and get one of those little peat moss planter kits..... That way if they sprout I can just transplant them. Also, been wanting to try a few other veggies.... peppers!!
/ B7500 and plowing
Update.
The seeds... Got one of the little planter things and tried about 10 different seeds from last year and 9 sprouted. Now, I love those little planter thingys!
The plowing.
After tilling the garden I was amazed on how deep I can till. I tilled deeper on one pass than I did on two passes in previous years. I hadn't really thought just how deep a plow, ah, plows.
I'm pretty sure that next year will be a tilling year and every other year a plowing year...then again I may plant a hardy crop of winter cover of some type and plow it under for the 2005 garden...ya know a little more seat time.
/ B7500 and plowing
</font><font color="blue" class="small">( Boman,
ten lashes with a dirty grease rag!!!! you didn't post pics. )</font>
I'm good lookin' enuff I don't need to post pictures of me. Geez you folks kill me. Ah, oh, pictures of the plowing... Lets see, I can harvest my stuffies this fall, turn over the garden with the plow... PICS and then till and sew with a cover crop. I'll try to do that.
2009 ALLMAND MAXI-HEAT MH1000 HEATER (A68842)
2009 ALLMAND...
PALLET WELDING SUPPLIES/TOOLS (A67714)
PALLET WELDING...
2025 Auger with Bits Mini Excavator Attachment (A66734)
2025 Auger with...
2004 POLAR TANK CRUDE PUP TRAILER (A67714)
2004 POLAR TANK...
2016 CAT 299D2 SKIDSTEER W/MULCHER HEAD (A67714)
2016 CAT 299D2...
2014 Chrysler 200 Sedan (A64557)
2014 Chrysler 200...
