b7500 50hr service
/ b7500 50hr service #1
Anonymous Poster
Epic Contributor
I just pruchased all the flters and fluids for my 50 hr service. The filters the dealer sold me do not look like the filters on the tractor. 1 oil and 2 hydraulic, The part #s are 70000-15241 oil?,67955-37710 and 66021-36060 I have checked several sites and these seem to be the correct filters and I am pretty sure the oil filter is the 1st listed above but what about the other 2.
/ b7500 50hr service #2
The 66021 filter is the one that goes on the left side of the transmission. The filter that goes on the right side (as you are sitting in the seat) should be longer and is gray. It will be a bear to put on unless you take off the rear wheel and take off the strainer (you are suppose to clean this at the 50 hour service) before you try to put on the filter.
taxman
/ b7500 50hr service #3
keng8,
I'm getting ready to do my 50-hour service on my B2410. The 67955-37710 and 66021-36060 are the part numbers I was sold for the two hydraulic filters. The B7500 and B2410 use the same hydraulic system, so these would seem to be right for you. My engine oil filter p/n is different than the 70000-15241 number (also makes sense - different engine)
Rob
Thanks for the info taxman. I had already planned on removing the wheel. It looks like it would be to tight a space to work in.
keng8
/ b7500 50hr service #5
Those are the correct part numbers - they are the same ones that are on an invoice I have for
filters (oil and hyrdo) that I purchased and installed.
You will have to take the tire off to change the hyrdo filter; it's heavy. I couldn't figure out where
the strainer was when I changed mine, so will have to clean that the next time.
213121 (A64276)
213121 (A64276)
2026 Electric Tricycle (A64194)
2026 Electric...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
2012 MACK GU713 DUMP TRUCK (A63276)
2012 MACK GU713...
MECHANICAL 4R48" FINGER TYPE SETTER (A64278)
MECHANICAL 4R48"...
2015 International 4300 Elgin Broom Bear Sweeper Truck (A64556)
2015 International...
