Oil & Fuel B7200 wont restart
   / B7200 wont restart #1
bedway
I was down in the woods dragging out some logs when i ran out of diesel. First time for me so i got some fuel and added it but the engine just coughed a few times but wont start. Im pleading stupidity,,help?
   / B7200 wont restart #2
If you have your owners manual it should show you how to bleed the air out of the lines , it will also tell you not to run it out of fuel for the very reason you are having now . Good luck as I have not had to do this , maybe someone will chine in with more info . .My manual just says to " fill the tank and start , run for 30 sec. and shut off ) . Not much help if it won't start .
   / B7200 wont restart #3
Crack the fuel lines at the injectors and turn it over until fuel comes out of all 3 lines. I'm pretty sure that's how I did it.
Good luck.
   / B7200 wont restart #4
There should be a bleed valve/nut on the fuel pump. Just open it and crank till fuel comes. Close and keep cranking. It should start.
Went through this procedure many times with a B7100.
Dump Truck Body with Tarp System (A55852)
Dump Truck Body...
2012 Cadillac SRX SUV (A55853)
2012 Cadillac SRX...
2016 Kia Soul SUV (A55853)
2016 Kia Soul SUV...
Abaco Machines DVL500 Vacuum Lifter (A55852)
Abaco Machines...
2004 IC Corporation 3000IC School Bus (A55852)
2004 IC...
2025 FUTURE X-DM43 SKID STEER DISC MULCHER (A58214)
2025 FUTURE X-DM43...
