B7200 NO FORWARD OR REVERSE
/ B7200 NO FORWARD OR REVERSE #1
LT67SS
I HAVE A B7200 SERIAL HD52129 WENT TO USE IT TUES. FOR FIRST TIME THIS YEAR AND I HAVE NO FOWARD OR REVERSE.I CHCKED ALL LINKAGES AND ALL SEAM OK. I DID NOTICE A SMALL AMOUNT OF FLUID UNDER REAR OF MACH. I CHECKED THE FLUID LEVEL AND IT IS FULL AND CLEAN.ANY IDEAS? THANKS!!!!!
/ B7200 NO FORWARD OR REVERSE #2
Is it gear or HST? Did it make any noise when you tried to move it or give any sign that it was trying to move? Did the clutch feel normal? Did you try a different range/gear? Did the range/gear shift feel normal? Did you try to move it while in neutral? ...maybe "neutral" now selects a range or gear.
/ B7200 NO FORWARD OR REVERSE #3
Hi, I have experienced a similar problem on a B6200. If your tractor is a gear drive. Remove the top cover where the shifter is. you will have to remove a few other things to get to it. Take your time and do not force anything. With the cover off check out the shifter plates they are bolted to the cover. Maybe they are worn or something like a pin fell out.
Good Luck!
2013 VOLVO VNL630 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2013 VOLVO VNL630...
2022 EZ-GO ELITE...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
2018 HINO 338 4X2 S/A 26FT FLATBED (A59912)
2018 HINO 338 4X2...
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
2011 FORD F-750 CHEMICAL TRANSPORT TRUCK (A65643)
2011 FORD F-750...
