B7100HST Mower engagement problem
   / B7100HST Mower engagement problem #1
Michialb7
Grove City, Ohio
B7100HST
I am looking at a 1983 B7100HST-1300 hours with a belly mower. The owner said he has problems when trying to engage the mower. it makes a grinding gear noise. I talked to a Kubota service mechanic but he said he was not for sure what the problem was until he seen the tractor. He also said it could cost up to $600 for labor and possibly$400 for parts if they had to repair something inside the case.
The seller is asking $4000 for the tractor as is. Is this a descent price considering it needs repaired?
   / B7100HST Mower engagement problem #2
Welcome to TractorByNet!
We moved your thread to the Kubota Owning & Operating forum. :)
   / B7100HST Mower engagement problem #3
Even though it is a HST, the clutch must be depressed all the way in when engaging the mid pto which drives the mower. If grinding gear clashing sounds still occur with the clutch fully depressed, I would suspect the clutch requires an adjustment or being a 30 year old unit, it may need replacement....I'd offer $3500 and hope its only adjustment.
I called them again and they said they tried adjusting the clutch so it sounds like it will need replaced. They said they would take 3500. I plan on looking at it and take 3200 in cash, what do you think knowing it will need a new clutch?
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
2016 PETERBILT 587 (A50854)
2016 PETERBILT 587...
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A50854)
2018 WACKER NEUSON...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2018 PJ 30+5 GOOSENECK TRAILER (A50854)
2018 PJ 30+5...
2016 MACK CXU613 DAY CAB (A51222)
2016 MACK CXU613...
