B7100HST hydraulic pump specs
   / B7100HST hydraulic pump specs #1
coralhead
Floyds Knobs, IN
kubota B7100hst Branson 4520r Massey Ferguson 135 diesel
Can anyone tell me what the auxilary hydraulic capacity is when connecting to the manifold block? What is the gpm on the pump and the pressure relief valve set at? I am wondering if it would run a small log splitter or has anyone tried this. The log splitter has a directional control valve. I am thinking that if the tractor can run a FEL than it may be able to split wood.
Any thoughts?
   / B7100HST hydraulic pump specs #2
Welcome to TBN. I have a B6100, similar tractor but smaller engine. I would think the pump would split wood (runs 1200 psi?) but it only puts out 3gpm or so. This would mean a really slow cycle time. Search around on this site and you'll see folks have done it with larger machines but the cycle time seems to be the typical complaint. Regular splitters typically have 2 stage pumps.
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
2020 RoGator RG1300C Spreader (A53342)
2020 RoGator...
2013 Nissan Pathfinder SUV (A51694)
2013 Nissan...
2020 JOHN DEERE R4023 LOT NUMBER 94 (A53084)
2020 JOHN DEERE...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
