B7100HST HST Issue
   / B7100HST HST Issue #1
IL4now
Mokena, IL
Kubota B7100HST
Hello - new to the site....
I have an issue where the tractor wants to keep moving only when there is a force working against it. For example when pushing mulch backwards with my blade. The tractor will work fine when pushing a small amount. The issue starts when I reach the point where traction or power to move the mulch comes into play. I release the HST pedal and the tractor will continue to drive backwards until I press the HST forward pedal slightly. The tractor will do the same this forward too.
I have searched this issue on the forum here and have done basic troubleshooting. I verified the roller is centered on the V bracket and that no branches or anything was in the way. I also centered the adjustment for forward\reverse via the access plate on the side.
Again, when just driving around normally the HST works fine.
I would appreciate any help.
Brian
   / B7100HST HST Issue #2
My B7100 did the same thing and the good folks here suggested that I check the clamp on the HST input shaft. The clamp was loose and caused a dead spot in the control.
Tightening that clamp made a big improvement but I still have a bit of creep at times. I think that's just because the linkage has a bit of wear and play.
Welcome to TBN
Hi Steve thanks for the quick reply
I know this is for a B1550, but do you know if the input shaft clamp you are describing is shown here?
  • Neutral holder B1550HSTD.pdf
John Deere 1775 NT Exact Emerge 24 Row Corn Planter (A52349)
John Deere 1775 NT...
KMC 3360 4-row Basket Dump Peanut Combine (A52128)
KMC 3360 4-row...
Mayrath 10 x 31 Truck Auger (A50514)
Mayrath 10 x 31...
Seppi Mini BMS 85 Mulcher excavator attachment (A52128)
Seppi Mini BMS 85...
Orthman 9300 4 row cultivator (A52128)
Orthman 9300 4 row...
UNUSED KIVEL HANG ON WHEEL LOADER PALLET FORKS (A51244)
UNUSED KIVEL HANG...
