B7100HST 3PH Arms won't lower
   / B7100HST 3PH Arms won't lower #1
tuppy
Can't get the 3PH to function. Lever moves front to back but arms are stuck in the up position and won't go down. Anyone got any tips on getting it to work?
   / B7100HST 3PH Arms won't lower #2
Do you have anything attached to it? If there isn't any weight on them mine will not go down either.... resting a foot on it while the lever is in the down postion gets the job done.
   / B7100HST 3PH Arms won't lower #3
Did someone close the valve?
   / B7100HST 3PH Arms won't lower #4
Do you have adjustment rod on the right side which could have loosen?
I don't have any equipment attached, but I've stood on the them with no result.
Do you mean the valve with the "T" handle under the seat? Not sure what is open position.
The adjustment rod is adjusted to allow full range of motion.
   / B7100HST 3PH Arms won't lower #8
Turning this valve may resolve the problem.
   / B7100HST 3PH Arms won't lower #9
The valve under the seat is like most leftee loosee! Rightee tightee!!!!
   / B7100HST 3PH Arms won't lower #10
Any luck?? My 3PH arms won't go down either. I have a backhoe semi-permanently mounted, so it doesn't really matter, but I've stood on the arms and they won't move. I've tried the valve under the seat at both extremes, with no effect.
JayC
5ft Rotary Tiller (A51573)
5ft Rotary Tiller...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
378645 (A51573)
378645 (A51573)
2011 NORMAN POWER SYSTEMS 100KW GENERATOR (A52472)
2011 NORMAN POWER...
