B7100HST 3 Point Hitch releif valve shims.
   / B7100HST 3 Point Hitch releif valve shims. #1
jas67
Platinum Member
Central PA
Kubota B7610 + Kubota G1800-S
Are these Kubota specific?
My 3 Point Hitch relief valve kicks in at a little below 1500 PSI, but is rated for 1700 PSI. With its anemic 400 LB lift rating, the 3PH on this tractor needs every last little bit, so I want to get it back to rated pressure. Need I go to the dealer on this, or can I use something that I can buy at the local hardware store?
Thanks,
Jay
   / B7100HST 3 Point Hitch releif valve shims. #2
I know on the L series they were just using small #6 # 8 #10 washers to shim. I'm not sure if your tractor uses the same. Not sure what that would cost you at the dealer.
   / B7100HST 3 Point Hitch releif valve shims. #3
medicshawn,
Get the shims at the dealer so you have the right stuff - couldn't be more that $5.00.
Use a 3000 # gauge on the pressure side so you know where you are - don't just throw in a handful of shims and hope for the best as pumps are fairly spendy.
Good luck!
medicshawn,
Good luck!
I already have a 3000# gauge with quick connects, and it is inline with my power beyond loop. This is how I know that the relief valve is set too low.
I called Messick's today, and spoke with the service tech. He didn't know of any Kubota part numbered shim. He said that they just get thin washers "off the shelf", but that their no official Kubota parts. I have some .010" shim stock that I think I'll cut some shims from. I read a thread elsewhere on here that stated .010" should give about a 40 PSI boost. I'll try one, and see how much boost, and then do the math to estimate what I need. The relief valve on my loader is set to 1700 PSI, so if I put too much shim in, the relief valve on the loader will limit the pressure passed on to the 3PH.
J.
Where is the plug for the 3PH relief valve on a B7100?
Thanks,
Jay
   / B7100HST 3 Point Hitch releif valve shims. #6
Thanks,
Jay
I would be interested in a picture of where it lives, if anyone has one handy?
   / B7100HST 3 Point Hitch releif valve shims. #8
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2020 Chevrolet Tahoe SUV (A50324)
2020 Chevrolet...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
John Deere 700 Hydraulic Hay Rake - Durable Side Delivery Rake for Efficient Windrowing (A52748)
John Deere 700...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
