B7100 w/ B219 Loader: Valve Question
   / B7100 w/ B219 Loader: Valve Question #1
ojaikubota
I have a B7100 4WD with a B-219 loader. The lever on the control valve which operates the bucket angle is seized solid; the up-down lever works fine. I can't seem to find a part number for the valve. Can any 2-spool valve be used? Does anyone have experience of repairing the original valve or replacing it? Should I go with a genuine Kubota part? Is there a chance that the valve is OK and the cylinder seized? -- how can I tell?
Thanks everyone.
JT
   / B7100 w/ B219 Loader: Valve Question #2
I've had valves Freeze? Water in the caps on bottom of spools.
   / B7100 w/ B219 Loader: Valve Question #3
Welcome to TBN:D
I would guess with some careful inspection your valve can be saved, It could be a simple linkage problem, or the spool could have a little rust on it.
Have you done any dis-assembly of the valve? If you don't feel comfortable you could take it to a local hydraulic shop and have them take a look.
If yours cannot be repaired, then this joystick valve from the SurplusCenter is a great replacement.
   / B7100 w/ B219 Loader: Valve Question #4
ah that's terrible, well it's junk now so i'll go ahead and take the loader off your hands and relieve you of that non working jalopy.
just kidding, welcome aboard, these jokers will get you straight quick.
TOYOTA 8FGCU30 FORKLIFT (A50854)
TOYOTA 8FGCU30...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
STORAGE FEES (A51219)
2018 East Texas 20ft Utility Trailer (A49461)
2018 East Texas...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
