b7100 tire problem
/ b7100 tire problem #1
1baddtoy
I need front tires for my b7100 4x4 and dont know what size I need. It has 29/12.50r15 turfs on the rear and nothing on the front. I have the rims just no rubber. I was told that I need a 6-12 or a 23x8.50-12. Any thoughts??? I did find a set of 6-12 that are bar tires will that work? Thanks.
/ b7100 tire problem #2
The 23x8.50 sounds right for use with the rear turfs. I can't remember if they have the 12 inch rim tho or not.
/ b7100 tire problem #3
For R1's (bar) 6-12 tires on the front with 8-16's on the back.
For turfs, you need 29x12-15 on the back, and 20.5x8-10 on the front.
can I run the 6-12 on the front and the turfs on the rear? The local kubota dealer couldnt tell me crap about this. they said it shows 6-12 fronts that are turfs for $100 ea. I found 6-12 fronts that are bar tires online for $130 a pair.
/ b7100 tire problem #5
No, they are too large in outside dia.
8-16's are about 31 in. in dia, where the turfs are 29 in.
ok so I found a set of at101 chevrons that have a mounted diameter of 20.9in. will these work? I am having a real hard time finding tires. Kubota keeps saying that I need a 6-12 but I have turfs on the rear and I dont want to buy wheels and tires for that too...
/ b7100 tire problem #7
You've only 3 posts.
Use the search feature.
There's a place that sells and ships "blems" fo a real reasonable price.
It doesn't matter how many posts I have. I have been searching online (this site and others) and calling multiple dealers for almost two weeks and I can't get the answer I need.
2025 Auger with Bits Mini Excavator Attachment (A66734)
2025 Auger with...
2005 FRAC TANK 500BBL WHEELED (A68842)
2005 FRAC TANK...
HEAVYEQUIPMENT HOSES (A68842)
HEAVYEQUIPMENT...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
1993 Brenner 307 SS Insulated T/A Chemical Tanker Trailer (A68183)
1993 Brenner 307...
2009 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2009 INTERNATIONAL...
