B7100 test glow plugs
   / B7100 test glow plugs #1
masscity
Platinum Member
NW UP of Michigan
L3540HSTC-3 B7100DT Ferguson TO-35
I had some trouble starting my B7100 last winter, so I decided to check out the glow plugs.
I tested them one at a time and each glowed bright red. Or do I have to test them with all three hooked at the same time.
thanks
   / B7100 test glow plugs #2
I just asked one of my shop guys about that and he said they test them one at a time off a battery charger, so I think you're good to go on the plugs.
Thanks Bob. I was thinking that it would be ok. I'm going to clean up all the connections and I should be good to go.
   / B7100 test glow plugs #4
thanks
You don't say what the temp is or how long you glow this thing. Is this new to you or have you had it a while??
The B7100 needs a lot more glow time than the newer ones.
   / B7100 test glow plugs #5
I know my 7100 is not an easy start in the winter. I installed a lower radiator hose heater and that makes starting much, much easier if you plug it in 30-45mins before you need it. I think I paid $25 at a car parts place for the heater.
I probably wasn't clear when I first posted.
I removed all three glow plugs, I hooked up each one at a time to the incoming glow plug wire, grounded it and turned the ignition left to preheat.
At about 15 seconds each glow plug would become bright red.
I bought this tractor brand new 30 some years ago. Except for last winter it has always been a good starter.
Maybe I had some bad fuel or something. I use one those magnetic oil pan heaters, which helps.
I've thought about one of those bottom radiator hose heaters, but I thought it would be too hard to install. Not much hose down there.
Thanks again.
   / B7100 test glow plugs #7
I just placed my order for a lower radiator hose heater for my B6100. I'll let you know how the install goes.
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A51039)
John Deere 1110...
Willmar 4300 Wrangler Loader (A51039)
Willmar 4300...
Landoll (A50657)
Landoll (A50657)
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A51039)
NEW 2024 LOAD...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
