B7100 starts lumpy
   / B7100 starts lumpy #1
stevemt
B7100
hi all my B7100 starts lumpy after it warm up its fine. noticed it happen after I ran out of fuel run the glow for about 25 seconds and starts after about the 5 turn
   / B7100 starts lumpy #2
Might have a little bit of air in your fuel system that will take a while to work itself out, could also be cold weather.
   / B7100 starts lumpy #3
May have air bleeding in to the lines while its sitting. Look for fuel leaks on your lines. If it is leaking fuel air can get in through these leaks.
checked all of the fuel lines I'm staring to lean towards the glow plugs herad a story of the tip of a worn glow plug dropping off and going into the cylinder. don't know if that is an old wives tale or not. B7100 sits in a nice shed so the cold doesn't get into its bones
   / B7100 starts lumpy #5
Have you tried adjusting the throttle setting for start up?:)
2007 JOHN DEERE 7630 TRACTOR (A53843)
2007 JOHN DEERE...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
2022 Padget Morris Electric Mobility Scooter (A54815)
2022 Padget Morris...
Kubota SVL95-2 High Flow Cab Skid Steer (A53473)
Kubota SVL95-2...
John Deere BD1108 (A50123)
John Deere BD1108...
