B7100 slow hydraulics
/ B7100 slow hydraulics #1
double hunter
Ford 1715
I have a buddy who has a Kubota B7100, 4wd, front end loader, the tractor is in good cond., runs great but the hydraulics are sloooow motion, what would cause this, what can we check, thanks for any help or advice
/ B7100 slow hydraulics #2
Sounds like either restricted flow (gunked up filter or debris in system) or the pump is starting to lose it's fit tolerances to wear. You might try putting a post in the Hydraulics forum, if you haven't already, as there are some real hyd experts over there.
/ B7100 slow hydraulics #3
I just posted my experience cleaning the hydraulic filter and fluid. Search: B7100 hydraulic filter change MLD. I do go on a bit but there is some info in there. It is not hard to do once you know what to do. Just some large metric wrenches 27 mm and 22 mm as i remember an oil pan and fluid . My filter came out easy and cleaned up like new. Of Course this was an older gear drive
and may not apply to your machine. It fixed the problem completely. Good luck I'll look for your post.
MLD
LOAD OUT AND SHIPPING (A65583)
LOAD OUT AND...
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
Horse Trailer (A62613)
2021 Bobcat T770 (A64126)
2021 Bobcat T770...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
