B7100 Seat bolt
   / B7100 Seat bolt #1
ackhamp
Hi
I need to find a bolt for a B7100 for the bracket that fastens the seat to the tractor body. I was told it has to be a special bolt because it has to expand and contract with the heat for the tractor. I was also told a grade 5 or grade 8 won't work. The bolt is 1/2" x 1 1/4" I tried a regular bolt and it leaks a bit? Is there anything I can put on the bolt to help it seal?
Any help would be appreciated.
   / B7100 Seat bolt #2
Hi
First off you were given information by somebody that knows nothing of what they are talking about. Secondly, the only way that bolt is a standard bolt and not metric, is if somebody is if somebody already rethreaded the hole, or forced a 1/2" bolt into a 12mm hole.
Brian
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A53472)
UNVERFERTH 330 -...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53472)
2019 Krause...
8" & 10" I BEAMS & 6" & 8" CHANNEL IRON UP TO 25' (A51247)
8" & 10" I BEAMS &...
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
2022 John Deere 333G Track Loader (A53342)
2022 John Deere...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
