B7100 Need help with my rear wheels
   / B7100 Need help with my rear wheels #1
Randybee1
Alright, Someone want to clue me in on which way my rear tires mount? Does the spring tensioner (that tightens to the axle) go on the inside of the rim (nearer the differentail) or does it go on the outside ? (same side as the lug nuts). Mine is on the inside but it looks like the service manual and parts manual is showing them mounted to the outside.
Thanks for any help!!,,, Randy B.
   / B7100 Need help with my rear wheels #2
If I recall correctly I think that your rims have been reversed to widen the stance. Mine is on the inside also, but it was like that when I bought it.
Someone will be along shortly with a definite answer.
   / B7100 Need help with my rear wheels #3
Mine were on the inside of rim, but there are several mounting positions to determine rear wheel width.
   / B7100 Need help with my rear wheels #4
On the inside. The other way you will not be able to remove the tire without removing tension assembly.:D
Thanks guys, It looks like "inside" is the correct location. Randy B.
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
New/Unused AGT MX-MRT14 Mini Skid Steer Loader (A51573)
New/Unused AGT...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2009 Volkswagen Jetta Sedan (A51694)
2009 Volkswagen...
New 40ft High Cube 6 Door Container (A53002)
New 40ft High Cube...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
