B7100 ~ More power?
/ B7100 ~ More power? #11
Did he put a V8 in it? Since I got into antiques, I have seen the Funk V8 conversion using a flathead Ford V8 in the 8N/9N.
Looks cool with zoomie type exhaust sticking up there!
RobertN in Shingle Springs Calif
/ B7100 ~ More power? #12
Always keep your thumb OUTSIDE the steering wheel. Seen em get busted while 4wheeling in the Jeep. Running older rigs w/o PS on the rocks, well they'll all the sudden spin the sterring wheel when you bump a rock.
My B8200, nor the new Farmall "A" have PS... Thums outside those steering spokes!
/ B7100 ~ More power? #13
Bird, did they say if it was governed?
I wondered about that on this Farmall I got. It's goverened for PTO speed. From the books, you just run it up in rpm. But, that assumes the governer is set correctly...
Thanks for the tip about the throttle setting, I was unsure about that. I haven't been running that fast. Also, thanks for the tip about the knucle bruiser, I'll try to keep a tight grip. I agree about the lack of gauges, so far that is the only thing I don't like. Has anyone installed a temp gauge on the 7100? If so, where did you find a plug to install the sending unit?
/ B7100 ~ More power? #15
RobertN, I'm certainly no diesel mechanic, but aren't they all governed in one way or another? And I'm pretty sure the guys were right about the PTO speed on the B7100 without a tachometer. Now that I have a B2710 with a tachometer, PTO speed is 2584, rated hp speed is 2600, but wide open throttle gets somewhere close to 2800, so wide open, then ease off just a bit would get you there on this B2710 also./w3tcompact/icons/smile.gif I'll admit to not having torn down a diesel engine of any kind, so I'm not entirely sure how the governor works, but my shop manual does show how to disassemble and re-assemble the "governor shaft."
Bird
/ B7100 ~ More power? #16
Tape it tightly to the upper radiator hose. Then put a layer of insulation, then tinfoil and tape it again. Should read within 5 degrees of a block mounted unit. If you decide to remove it, it is easy.
/ B7100 ~ More power? #17
Dennis, with the B7100 not having a water pump nor a temperature gauge nor a coolant recovery jug, I was a bit concerned about that, but a factory service rep told me not to worry about it. He said if it starts to get hot, "You'll hear it whistling from steam escaping."/w3tcompact/icons/frown.gif (They did stress keeping a clean 50/50 mixture of water and anti-freeze, not any stronger mixture, in the radiator.) Fortunately, mine never whistled./w3tcompact/icons/smile.gif And while I didn't ask how, where, etc., one dealer told me he could install a tachometer for about $200, so I decided I could live without it.
Bird
/ B7100 ~ More power? #18
You grew up on a "green" tractor; did it have a tach? How did you control PTO speed on it? This Farmall "A" I just got does not. Does have a oil pressure gauge though :) I do wonder how they set a governor on a tractor that has no tach. They must have one they hook-up just for the procedure, I'm guessing. On the B7100, there must be a service port for hooking up a tach. Or, a person could use the add-on versions where a sensor an pickup are added on the crank pulley.
For the B7100, it should spit and whistle like this old Farmall "A", as it is a thermo-siphon system right? There's no waterpump. The cooling system is non-pressurized, yes?
It's interesting how they still make use of the thermo-siphon system after all these years.
/ B7100 ~ More power? #19
RobertN, that "green" tractor I started on didn't have any gauges, and it didn't have a PTO either (had PTOs been invented by then?). The only implements we had were a single bottom turning plow (I never heard the word "moldboard" back then), a double buster, and the remains of a horse drawn disk (still had the seat on it so someone could ride on it for ballast, but Mother refused to ride it after Dad went over a terrace and flipped her off backwards once).
And for those of you who don't know what we're talking about, my first experience with a tractor was a small 2-cylinder gasoline John Deere that I always seemed to remember Dad saying he thought was a 1940 model, but after looking at some information Robert gave me, I think it must have been a 1938.
And yep, the B7100 has what we call a thermo-siphon system, but that factory service rep had another name for it and I've forgotten the word he used. But it did have a pressure cap on the radiator.
Bird
/ B7100 ~ More power? #20
Re: B7100 ~ (Temp Gauge)
On my B7100, I bought a mechanical temperature gauge and had a radiator shop solder in a fitting in the top of the radiator right next to where the top hose enters the radiator. I get pretty good results at that location. Since my B7100 is an older model (doesn't have an hour gauge) I mounted the temperature gauge where the hour meter wouldv'e gone.
I won't go into it here, but you need to be aware of the B7100's thermo-siphon cooling system (no thermostat; no water pump). If you are interested, I will also go into the "max temperature" calculations. Don't believe the generic dealer answer "max temperature is approximately 100 degrees above ambient". I can (and have) prove that to be incorrect.
While mowing with my mid-mower, I find the B7100 to run cooler at full throttle than it does where I used to run it (about an inch off of full throttle). I can only assume more airflow across the radiator to be the reason.
Hope this helps
Kelvin
Adams 5 T Fertilizer Spreader (A61307)
Adams 5 T...
Sdlanch SDLD25 (A60463)
Sdlanch SDLD25...
2021 CATERPILLAR 302.7DCR EXCAVATOR (A62129)
2021 CATERPILLAR...
Chandler Equipment 20' Litter Spreader (A60462)
Chandler Equipment...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
