B7100 loader and belly mower compatibility
   / B7100 loader and belly mower compatibility #1
Frank
Northeastern Ohio
BX 22 trade-up from 2200
I'm interested in buying a B7100. Can anyone tell me what "quick attach" loader is compatible with using a belly mount mower deck? I've looked at two so far (one with a quick attach Du-Al Model 95 loader and one with the Kubota 1630 fixed mount) and both had a subframe which the dealer said prohibited the attachment of a belly mower. Is there a "quick attach" Kubota or other brand loader that can be installed while leaving enough clearance for a bellow mount? Does it make any difference whether the 7100 is an original 80's model or a 90's reissue? New to the forum. Appreciate any help.
   / B7100 loader and belly mower compatibility #2
Frank, I bought a new B7100 in 1995 with the B1630C fixed mount front end loader. I've never had a belly mount mower, but I do recall the salesman telling me that the ability to use a mid mount mower without removing the front end loader was one of the features of the "new" B7100s.
Bird
   / B7100 loader and belly mower compatibility #3
Note 1: The are a few differences between the older ('70s-'80s) B7100s and the newer B7100s (late '80s through late '90s). For the purposes of this discussion I beleve that the wheel base is different thereby affecting loader availability. The B1630 Rigid Loader will only work on the newer B7100s. After much searching I did not find any loaders available for my older B7100 (even though a Woods salesman told my he had a brand new Woods model; after closer inspection we found the note saying that it would not work on the gear-drive B7100s).
Note 2: According to my B7100HSD Sales Brochure (dated 1996) the B1630 Rigid Mount Frond Loader is "not compatible with the mid-mount mower". However, my "Kubota Front Loaders" sales brochure (also dated 1996) says that the B1630C "loader is compatible with the RC54-71B and the RC60-71B mid-mount mowers". Either one of the brochures is lying or the "C" added on to the end of the Loader model number makes a big difference.
Based upon my research, I don't believe that it is cost-effective to buy a B7100 and try to add a loader to it. I don't believe that there is much price difference in any of the B-series loaders, but there is a lot of performance difference. If you added a loader to the B7100, it probably wouldn't be long before you would want to upgrade to power steering or more loader performance. If you found a B7100 with loader reasonable priced then that may be worth considering. Even with that I would seriously consider a 3-point mower if the B7100 was a hydrostatic model.
Bird,
Thanks for the response. Do you recall if a quick-attach loader was also an option back in 1995?
Frank
   / B7100 loader and belly mower compatibility #5
Frank, unfortunately a quick attach loader was NOT available in 1995 (a fact that made me seriously consider a Cub Cadet before I decided on the B7100). It would have been a major job to remove the loader, so I never did.
Bird
Kelvin,
Thanks for sharing your experience with both the old and the new 7100. I haven't been looking that long, but it seems like all of the "quick attach" loaders on B7100s I've seen so far are not compatible with a belly mount mower. For anyone else interested in this topic, I did find a post in the archives which sent me to "easternfarmmachinery.com" whose catalogue includes a Frey Model 2010 loader which claims to be compatible with undermount mowers on compact tractors. Cost is $2240. You may be right, however, that it is not really cost effective to buy a a 7100 and then add the loader. -Frank
   / B7100 loader and belly mower compatibility #7
We have a woods du-al loader on a B2150 for rental use. It is still going. Yes, you can mount a belly mower on the loader subframe. Yes it is a quick tach loader.
Kubotaman,
Thanks for the reply. I believe the 2150 has a longer wheelbase than the 7100, and probably higher ground clearance. Two questions, for you or anyone else out there who might know: 1) Would the same set up on a B7100 with less ground clearance work? 2) What model belly mower is mounted on your machine? Thanks again. Frank
   / B7100 loader and belly mower compatibility #9
I am not sure what point Kubotaman was trying to make, but I don't think he was suggesting that the Woods loader for the B2150 will work on the B7100.
I have a B2150 with loader (no mid-mower) and a B7100 with mid-mower (no loader) and can reasonable assure you that there is no way (within reason) that the B2150 loader will work on a B7100.
I can't find it now, but I remember reading in one of the B-series brochures that the mid-mount mower's ground clearance was reduced by 1/2" or so when the loader was installed.
About a week ago there was a B7100 (w/loader) on the classified ads portion of this board you might want to check out.
   / B7100 loader and belly mower compatibility #10
B7100 Loader available...
For those interested, I saw a used B1630C loader for sale at the Knoxville TN dealership (I would guess that used ones are hard to find without a tractor attached). Repeating previous information, this model loader is supposed to work on the newer sytle B7100HSDs and will not work on the older gear drive B7100s. I didn't bother asking how much; (865) 687-5418 for those who want to ask.
   / B7100 loader and belly mower compatibility #11
Kelvin, the B1630C loader is what I got with my 1995 B7100. The only thing wrong with it was that it was not a quick attach model.
Bird
   / B7100 loader and belly mower compatibility #12
I have a 1994 Kubota B7100 HST with a Quick Attach FEL, Kubota Model LA300B which is compatible with my mid mount mower Kubota Model RC60-71B, all purchased in Saskatchewan Canada
Ken
   / B7100 loader and belly mower compatibility #13
Ken,
As I look through my newest Kubota front-end-loader (FEL) brochure as well as the Kubota FEL brochure from 1996 I don't see the "LA300B" loader mentioned anywhere. Was that loader built for Canada only? The closest that I come to that number is the LA301 which was built for the B1700.
   / B7100 loader and belly mower compatibility #14
Frank said:
Kubotaman,
I have a late (1998) B7100 with both quick-detach mid-mount mower (Kubota RC60-B71, I believe) and a Woods DuAl 145 quick-detach loader.
   / B7100 loader and belly mower compatibility #15
RC54-71B orRC60-71B mowers and LA300 loader will be compatible.:D :D
2021 Kubota SVL75-2 Track Loader (A61306)
2021 Kubota...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2005 TerraGator 8104 (A55302)
2005 TerraGator...
(125) PALLET OF UNUSED SAFETY CONES (A60432)
(125) PALLET OF...
John Deere 652R 52in Stand-On Commercial Mower (A56857)
John Deere 652R...
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
